    89 - only the best year ever. plastic bumpers + pop out rear windows.
      Agreed, 89 is the best year, followed by 87, then 90 and 91.
      I guess I dont have those window seals that you replaced then
        What reinforcement plates?
          these:
          https://www.ecstuning.com/b-ecs-parts/heavy-duty-rear-shock-mount-reinforcement-plate-set/002478ecs01kt/?gclid=CIbVlPuowNMCFdgDgQodu08Drw
            Definitely don't want to tear those rear shock mounts. I love you Ground Control rsm's=P
              this.
              small update from the body shop guys.
              fyi, going with no "rock guard" on the front valance. should be purty.
                Gonna be sweet=)
                  Noooice. Cant wait to see it painted.
                    now, the real question is when am I going to get a phone call from the body shop because they cant get the coolant bled right? #swapcarproblems
                      Looks like its coming along really well!
                        Thatll be a fun call lol
                          What body shop are you using?
                            car is back from body work. the shop I used was Authentic Automotive. I give them a 7/10. They left my new carpet dirty as hell from their shop boots :rolleyes: so now I have to clean it, and (per my odometer) they drove the car 3 miles, and they had no reason to need to drive the car off their lot, so...
                            core support straightened and valance installed/painted.
                            got my spal fan installed. hooked up to run constantly on ignition, will have to figure out wiring to temp switch or a dash switch at some point.
                            front end put together.
                            i also got the rocker panels repainted, wheels installed, and rear suspension set to the right height. a bonus is that the 16" wheels/225 tires ride softer than the snow tire setup. i'm guessing its the cheap Nexen tires having squishy side walls. the car handles still handles very neutral with a bit of throttle oversteer. :)
                              Looks so good in the pictures.
                                Wow! Looks great!
                                White>Black any day.
                                I know that sounds wrong but its okay because I own a Black.
                                Im upset that they drove it though[emoji58]
                                  Maybe to re bleed the cooling system? And do a burnout maybe
                                    It's hard to find good, honest shops for anything which is why I was curious for when mine gets painted. Yours looks damn good!!
                                      Verifying the cooling system is bled is a legit reason to put a couple miles on the car.
                                        If it was a rusted out Chevy cruze LTZ+ do you think they would've taken it for a test drive?
                                          Looks great. White cars rule. If there was no damage done in the 3 miles it moved I wouldn't question it, probably just stoked to have an E30 in their shop. 😄
