  4. E30 coilovers or spring/shocks
34 Posts 9 Posters 502 Views 1 Watching
  • AsparagusMikeA
    AsparagusMikeA
    AsparagusMike
    if you have the initial budget and ability to get your struts welded, go for the coilovers. it will make it cheaper/easier to tweak your preference down the line.
    Yup I gotta a good friend that welds for a living so that won't be a problem.....I also just found out that the 91 318is has the 51mm strut housing, didn't know that. Also, for coilovers, what u guys think of the cx racing set? I read a couple other forums that they were a really good set for street use and hooligan activities, not so much for track though which is perfect! And a little cheaper then the bc racing ones.
    • AsparagusMikeA
      AsparagusMikeA
      AsparagusMike
      Lol didn't tag that write, I'm such a tard
        Hooligan-rated parts are best parts.
        you should send paypal right now
          i'm definitely a proponent of going with a kit that has a good reputation, so do your research on if the cxracing stuff is any good - i've never heard of it before.
            Isn't cxracing the same company that makes ebay turbo kits and things like that? If that's the case I wouldn't go that route for coilovers
              forgot to add, you're welcome to ride/drive/inspect my car if you want some baseline. i have BC coils, 6k/10k. the ride is.....direct? you feel everything, but it doesnt bother me in the least, i love it. your results may vary if you have a woman's opinion emanating from the passenger seat. the quality of the parts seems really good, we will see on longevity.
              • AsparagusMikeA
                AsparagusMikeA
                AsparagusMike
                That wouldnt be such a bad idea, how did you chose what spring rates you wanted for the front and rear?
                  its closest to the ie3/h&r race spring rates, which is the best compromise in handling/comfort for me. anything softer doesn't handle great and anything stiffer is just masochistic on WI roads.
                  • AsparagusMikeA
                    AsparagusMikeA
                    AsparagusMike
                    Straight6pwr, you live around or near the oshkosh area?
                      A good way to put it:
                      If eBay was weed it would be the shitty stuff sold by the sketchy guy in the back alley
                      Cxracing is the shitty stuff sold by someone not in a back alley, and puts it in baggies with their name on it.
                        milwaukee.
                        • AsparagusMikeA
                          AsparagusMikeA
                          AsparagusMike
                          Well when u say 6k/10k.....6k in the front and 10k in the rear? Or vise versa
                            Keep in mind that if you are selecting your own custom spring rates that the trailing arm creates a mechanical advantage that requires the rear springs to be extra stiff. If you choose a coil over that relocates the spring on top of the damper then that mechanical advantage is lost.
                            I have seen E30 kits come with both styles of rear spring. Over the damper, and in the stock location with an adjustable collar.
                            • AsparagusMikeA
                              AsparagusMikeA
                              AsparagusMike
                              Okay well the bc racing coilovers have the rear springs located in the trailing arm like the stock ones so that would just mean that I would need stiffer springs for the rear. That explains what straight6pwr did....10k in the rear while 6k in the front to kind of even it out because of the mechanical advantage
                                Yep, just as straight6pwr said, 6k/10k would be like h&r race spring rates
                                  I had H&R and Billys on my car and swapped over to BC's. I will always suggest BC's if you can afford it.
                                  • AsparagusMikeA
                                    AsparagusMikeA
                                    AsparagusMike
                                    Did u get custom spring rates?
                                      i would think you have to if you order them. I believe the 'e30' kit is going to have unbalanced rates like 6k/6k or 8k/8k
                                      • AsparagusMikeA
                                        AsparagusMikeA
                                        AsparagusMike
                                        Okay I'm running into an issue. I was going through about to order the bc racing br series coilovers and I called the company as well asking about this. I guess they no longer provide rubber top mounts for the e30 coilover sets, only pillow ball. Now I did some reading up on the pillow ball top mounts and people were saying that the ride isn't gonna be as smooth as the rubber top mounts. I guess I really don't have a choice cause thats all they offer. Should I just go for it anyways or maybe look at a different brand?....did they use to have rubber top mounts or was it always this way?
                                        • AsparagusMikeA
                                          AsparagusMikeA
                                          AsparagusMike
                                          This just for the front coilovers, the rear shocks have rubber tophats. I should also include that the guy from bc racing said that they do this so they can include camber plates for adjustment.
