  4. E30 coilovers or spring/shocks
34 Posts 9 Posters 502 Views 1 Watching
  • AsparagusMikeA
    AsparagusMikeA
    AsparagusMike
    Okay cool....I think I might as well get the coilovers cause I did want to lower the car slightly so that it looks better with 15 inch wheels. Speaking of wheels, what is your guys opinion on the team dynamics pro 1.2 wheels 15x7's? They seem to be really well made, look pretty good, and are reasonably priced.
      If still on stock parts with 118k anything you get will be an improvement. No surprise you're bouncing since stock dampers are shot if they've never been replaced.
      Combo choice depends on many things including your road conditions and how stiff a ride you like. Ride in other cars if you can since what feels good can be a personal choice.
      Sachs/Boge will be new stock, KYB as a cheap choice. Bilstein and Koni as much better step up. Koni are getting more love from some folks than Bilstein sport and/or HD for a street driven only car for less stiff of a ride on less than smooth roads.
      H&R OE sport, sport, race springs change ride hight and ride stiffness. Snap is right on the sport-race tradeoff. I noticed the same thing when the track e30 was still street driven.
      Also for anything but stock better get a skid plate for your car because an M42 oil pan already sits low and with any drop in ride height it's even more at risk.
      I've got Bilstein sports and H&R OE sports on the street driven only 91 318is. Feel every expansion joint.
        x1,000,000 if you can do this. you can make an educated guess, but its hard to say what you'd like if you've never experienced it.
        if you have the initial budget and ability to get your struts welded, go for the coilovers. it will make it cheaper/easier to tweak your preference down the line.
          The difference in handling is significant with the Race springs and the ride quality penalty is minimal since the Sports always bottom out (too soft for how low they are).
          You should cut the internal bump stops a bit. Its pretty easy to do and it sounds like it helps a decent amount
          http://www.r3vlimited.com/board/showthread.php?t=239380
            Choose an answer:
            A) it isnt a problem anymore now that I dont drive my car anymore.
            B) it isnt a problem anymore with h&r race springs.
            thanks for looking out for me
              Choose an answer:
              didn't read that well enough... option A should be corrected though
              • AsparagusMikeA
                AsparagusMikeA
                AsparagusMike
                Yup I gotta a good friend that welds for a living so that won't be a problem.....I also just found out that the 91 318is has the 51mm strut housing, didn't know that. Also, for coilovers, what u guys think of the cx racing set? I read a couple other forums that they were a really good set for street use and hooligan activities, not so much for track though which is perfect! And a little cheaper then the bc racing ones.
                • AsparagusMikeA
                  AsparagusMikeA
                  AsparagusMike
                  Lol didn't tag that write, I'm such a tard
                    Hooligan-rated parts are best parts.
                    you should send paypal right now
                      i'm definitely a proponent of going with a kit that has a good reputation, so do your research on if the cxracing stuff is any good - i've never heard of it before.
                        Isn't cxracing the same company that makes ebay turbo kits and things like that? If that's the case I wouldn't go that route for coilovers
                          forgot to add, you're welcome to ride/drive/inspect my car if you want some baseline. i have BC coils, 6k/10k. the ride is.....direct? you feel everything, but it doesnt bother me in the least, i love it. your results may vary if you have a woman's opinion emanating from the passenger seat. the quality of the parts seems really good, we will see on longevity.
                          • AsparagusMikeA
                            AsparagusMikeA
                            AsparagusMike
                            That wouldnt be such a bad idea, how did you chose what spring rates you wanted for the front and rear?
                              its closest to the ie3/h&r race spring rates, which is the best compromise in handling/comfort for me. anything softer doesn't handle great and anything stiffer is just masochistic on WI roads.
                              • AsparagusMikeA
                                AsparagusMikeA
                                AsparagusMike
                                Straight6pwr, you live around or near the oshkosh area?
                                  A good way to put it:
                                  If eBay was weed it would be the shitty stuff sold by the sketchy guy in the back alley
                                  Cxracing is the shitty stuff sold by someone not in a back alley, and puts it in baggies with their name on it.
                                    milwaukee.
                                    • AsparagusMikeA
                                      AsparagusMikeA
                                      AsparagusMike
                                      Well when u say 6k/10k.....6k in the front and 10k in the rear? Or vise versa
                                        Keep in mind that if you are selecting your own custom spring rates that the trailing arm creates a mechanical advantage that requires the rear springs to be extra stiff. If you choose a coil over that relocates the spring on top of the damper then that mechanical advantage is lost.
                                        I have seen E30 kits come with both styles of rear spring. Over the damper, and in the stock location with an adjustable collar.
                                        • AsparagusMikeA
                                          AsparagusMikeA
                                          AsparagusMike
                                          Okay well the bc racing coilovers have the rear springs located in the trailing arm like the stock ones so that would just mean that I would need stiffer springs for the rear. That explains what straight6pwr did....10k in the rear while 6k in the front to kind of even it out because of the mechanical advantage
                                          With your input, this post could be even better đź’—
