  4. E39 M5
E39 M5
76 Posts 18 Posters 1.4k Views 1 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    Ah alright, I was thinking of disassembling it and cleaning it, I'll add some loctite when I go back together.
      Yes loctite the bolts that hold the pump together.  I worked on one that had a bolt in the bottom of the pan and the rest were finger tight.  That was a '93, maybe they solved the problem later on?
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        Oil pump is in with loctite, drivers side window regulator is unfucked, picked up the last remaining parts I need to be able to drive it finally. ...annnnnd I have to work tomorrow.
          Good thing the weather still sucks
          • TehRaydarloverT
            TehRaydarloverT
            TehRaydarlover
            True, that nice weather we had was killing me.
            New left, right, and center tie rods, sway bar bushings, trans and motor mounts, shifter bushing, and z3 short shifter are all installed. Sub frame is back up, pretty much just have to put the fan/belts and the radiator back in. :DD
              Then you'll come over and do mine? 😉
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                Forgot to message you. We'll see, I want to make sure engine doesn't explode before I say I'll work on someone else's lol. I like to think I know what I'm doing, there are a bunch of nuclear and fossil power plants running at 100% because of my wrenching/engineering, but this is my first time dealing with anything with more than 1 cam haha.
                  Sounds good.  Car isn't going anywhere....not even sure how bad it is.  With 130K, could be needing some love.
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    Anyone have the socket "key" for this stupid thing? I want to take my wheels off 😕
                      That's not a typical bmw wheel lock. I've got a set of wheel lock removal sockets if you need them.
                        I'll check my supply and see if I have one that matches.
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          T-minus 20hrs until I come home from work to $84 in oil on my garage floor lol. Hood is officially down! Just need to do stupid coolant things.
                            This is when you find the oil pump driveshaft sitting on the workbench
                              I'm afraid I don't have the key if the bolt size is 17mm
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                Started the M5 last night! Runs and sounds awesome 😁 I'll be getting plates for it today after work, can't wait to put some miles on it! I'll try to get a quality video/pictures this weekend maybe. 😎
                                  I've got this sitting around if you want to grab it ...
                                  • TehRaydarloverT
                                    TehRaydarloverT
                                    TehRaydarlover
                                    Well I took it for a drive yesterday and right away it was misfiring really bad under load. I drove straight to kwik trip to get some fresh gas, talking with the PO the gas was probably well over a year old. Fresh gas helped a lot but it went into limp mode and still misses under load. I'm pretty sure I fouled the plugs, but any other ideas? I ran the codes and it had the same ones as before I started working on it. Secondary air pump, coolant temp, and bank one over retarded. Coolant temp I'm sure was just the sensor, and over retarded was the lack of timing chain guide. I'm thinking plugs because just cruzing it's fine only under load is it missing, but maybe it's the injectors?
                                      Excitement: it's running!
                                      Disappointment: something isnt right.
                                      Did it run like this before all the work?
                                      • TehRaydarloverT
                                        TehRaydarloverT
                                        TehRaydarlover
                                        Not that I know of but I didn't really get on it like I was yesterday. I'm going to pull the plugs and see what they look like. Maybe the coils are bad? Shouldn't I be getting some codes from it going into limp mode?
                                          Could this be vanos sensor/cam sensor related?
                                          Cam timing NOT changing under load and not jiving with the fuel and timing maps is the first thing that comes to my mind. Does it happen while revving in neutral?
