  4. E39 M5
E39 M5
76 Posts 18 Posters 1.4k Views 1 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    So here is where all of the little pieces of timing chain guide went... that's pretty f@cking terrifying. Really hoping this screen and the oil filter have done their jobs lol.
    • i_love_carsI
      i_love_carsI
      i_love_cars
      holy shit. I don't have a better response for that image lol
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
        Were there any loose bolts on the pump too?
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          The bolts that hold the pump itself together? Or that hold the pump to the engine? Either way they were all tight.
          I think I'll be doing an oil change after the first 50 miles just to try and get any left over pieces out, or at least a filter change.
          • damnboy037D
            damnboy037D
            damnboy037
            Nice work, looking forward for more updates.
            99 M3 320rwhp @ 6psi
            95 M3 s50b32
              I've had them both loosen on the m60b30's. One motor had 3 pump case bolts out and several loose and the other had one mounting boot out.
              I'd locktight them all when you put the pump back in so you don't have to worry about it later.
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                Ah alright, I was thinking of disassembling it and cleaning it, I'll add some loctite when I go back together.
                  Yes loctite the bolts that hold the pump together.  I worked on one that had a bolt in the bottom of the pan and the rest were finger tight.  That was a '93, maybe they solved the problem later on?
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    Oil pump is in with loctite, drivers side window regulator is unfucked, picked up the last remaining parts I need to be able to drive it finally. ...annnnnd I have to work tomorrow.
                      Good thing the weather still sucks
                      • TehRaydarloverT
                        TehRaydarloverT
                        TehRaydarlover
                        True, that nice weather we had was killing me.
                        New left, right, and center tie rods, sway bar bushings, trans and motor mounts, shifter bushing, and z3 short shifter are all installed. Sub frame is back up, pretty much just have to put the fan/belts and the radiator back in. :DD
                          Then you'll come over and do mine? 😉
                          • TehRaydarloverT
                            TehRaydarloverT
                            TehRaydarlover
                            Forgot to message you. We'll see, I want to make sure engine doesn't explode before I say I'll work on someone else's lol. I like to think I know what I'm doing, there are a bunch of nuclear and fossil power plants running at 100% because of my wrenching/engineering, but this is my first time dealing with anything with more than 1 cam haha.
                              Sounds good.  Car isn't going anywhere....not even sure how bad it is.  With 130K, could be needing some love.
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                Anyone have the socket "key" for this stupid thing? I want to take my wheels off 😕
                                  That's not a typical bmw wheel lock. I've got a set of wheel lock removal sockets if you need them.
                                    I'll check my supply and see if I have one that matches.
                                    • TehRaydarloverT
                                      TehRaydarloverT
                                      TehRaydarlover
                                      T-minus 20hrs until I come home from work to $84 in oil on my garage floor lol. Hood is officially down! Just need to do stupid coolant things.
                                        This is when you find the oil pump driveshaft sitting on the workbench
                                          I'm afraid I don't have the key if the bolt size is 17mm
