  4. 91 318 Nostalgia
91 318 Nostalgia
seriously anoth
89 Posts 16 Posters 1.6k Views 1 Watching
    I swapped the FPR on the car in attempt to help the hot start, as a lot of people online said that was their issue. It did not fix mine.
    I have a CEL for the coolant temp sensor, but the sensor is clearly new, and there is a receipt for it in the car. I don't know if I double checked the number, but it is blue like it should be.
    I have a feeling the CLT sensor is the problem, and I will check the sensor itself and then ensure that the wiring from the plug to the ecu is good. If I can fix the hot start issue I would feel much more confident in the car.
      Arbor press ftw
      If you pull the trailing arms out, sure.
      Two bolts ya chump!!!
        In addition to the cv (moot point) The brake lines, abs sensor, parking brake cable, shock, spring, and sway bar end link.
        Not to mention the difficulty of doing the bolts on the passenger side (fuel filler neck)
        In short, I did my last one in car.
          The tools I listed are the way to go=) It would take you a half hour to do each side if you're moving at a good pace
            Fab up a puller
              I had an e30 that had an intermittent problem with the temp sensor for the ecu.  It would surge at idle when it warmed up and sometimes wouldn't start, it was the corrosion in the plug.  I cleaned up the connection and it was fine.
                I think I half assed tried this earlier but couldn't quickly find anything to clean the contacts with.
                What did you use?
                  I think I used a pin or needle to scrape inside the female connector and then once I knew it worked I put some vaseline on the contacts with a Q tip to prevent future corrosion.  A tiny pin file would probably be good if you could find a small enough one.
                    CLT issue fixed.
                    Started by cleaning the contacts, then pulled the ecu connector and checked for continuity between the connector for the ecu and the sensor connector. Nada. Broken wires, b but where?
                    Grabbed a spare harness (thanks @HipMF for hoarding m42 parts) and doubled checked my test method on a different harness and confirmed that the one in my car didn't have the cotton-nuity.
                    Started pulling pieces off to gain access to the loom box under the intake and found that under the extremely brittle wire covering was a broken sensor wire, and one just barely hanging on. Patched those up and started it. CEL is gone! Car idled better than ever, and sadly there was another car in the way so I was unable to take it out to get it to temp and check the hot start issue. Though I doubt that still exists.
                    Progress.
                      Excellent!
                        Picked up a little treat yesterday.
                        I am not actually sure what car they will end up on though lol. The initial intent was for this, but I can adapt them to the perfect offset to run some good tires on the m52 car.
                        4 fronts, 2 rears. I can run a staggered set or a square set.
                          Glad you scooped these up!
                            Took the door panel off the drivers side to replace a broken door handle yesterday. It appears that at some point when a previous owner removed the drivers door lock they decided they didn't have enough room to access it so instead they just took a grinder to the door. Why?
                            2017-01-3007-38-10
                            Hot start issue is gone, which means we are throwing this thing into daily use even though I am still slightly hesitant of that!
                            New front control arms, control arm bushings, tie rod assemblies, tie rod boots, and strut tops were ordered yesterday to fix up the front bushings and ball joints. They feel okay but the ball joints are quite worn so I may as well knock it all out at once!
                            Now to tackle the blower motor. Only works on 4 and sounds bad, which usually means that one of the covers is hitting the blades.
                              i've changed a latch mechanism in an e30 sedan door. i wanted very badly to cut holes in the door and/or kill myself, so I can see where the PO was coming from.
                                If it only works on 4, chances are its the blower motor resistor, as 4 is the only speed that bypasses the resistor.
                                  Agreed, though due to the noise it makes I need to do further investigation.
                                    The fan noise could be a couple things: some debris got into the housing, the metal clip holding the motor in place came loose so the motor isn't seated properly, or the plastic fan blades/ hamster cages have partially disintegrated with age.
                                      I haven't seen the motor clip coming loose before.
                                      The last one I did the plastic had warped enough that it was sitting against the fan blades. That was a nice easy fix!
                                      Just transferred the title, and picked up plates for this. Daily duty may start tonight.
                                        Good deal!
                                        Not sure if it was a track concrete gator issue or the earlier wall tag, but when I opened up the housing on the track car the metal clip holding the blower motor was still in place but the motor itself had been slightly knocked out of the normal housing seat position and was rotated about 1/4" backwards towards the firewall.
                                        One more reason to keep yours a daily driver.
                                          I look forward to replacing the front suspension and tie rods on this. Driving home last night on the highway with wind, grooved road, snow tires, and worn ball joints was quite a bit of work!
                                          Trying to slide in this in the snow is different. It lacks the power that I prefer, but lift off over-steers quite well. I could certainly do without the beehive power plant!
                                          It's been doing me well though, and is certainly more enjoyable (even in mediocre condition) to drive than the Mazda!
