  4. 91 318 Nostalgia
91 318 Nostalgia
seriously anoth
89 Posts 16 Posters 1.6k Views 1 Watching
    Weeee! I got some snow tires!
    This excites me.
    I also got the car back on the ground!
    Next step is to take the lower pan off the motor and check the upper pan bolts as well as replace the lower pan (PO stripped the drain plug and failed to use a gasket when installing the lower pan)
      Took this out last night to feel how the new rear end felt, and all feels good! I fixed the PO's terrible exhaust work as well, so now the exhaust actually exits from the muffler!
      Sadly I found that what I had thought was diff whine before is in fact a wheel bearing that is close to giving up on life.
      I also have hot start issues, and am going to try replacing the FPR as most people claim that's what is common on these.
      I want to start daily driving it, but I don't trust it yet.
        Good thing e30/e36 wheel bearings are a cake walk=P
          Yeahhhh, about that.
          Though I have never used a proper tool set, and I believe Mr. Rice has one that I may be able to borrow.
            I have a slide hammer, front wheel drive bearing mandrel set, and large snap ring pliers set all from Harbor Freight that work great for doing 😃
              Wheel bearing party this weekend? I'll ordee one for the e34.
                Arbor press ftw
                  Arbor press ftw
                  If you pull the trailing arms out, sure.
                    Wheel bearing party this weekend? I'll order one for the e34.
                    I'm booked this weekend unfortunately
                      I swapped the FPR on the car in attempt to help the hot start, as a lot of people online said that was their issue. It did not fix mine.
                      I have a CEL for the coolant temp sensor, but the sensor is clearly new, and there is a receipt for it in the car. I don't know if I double checked the number, but it is blue like it should be.
                      I have a feeling the CLT sensor is the problem, and I will check the sensor itself and then ensure that the wiring from the plug to the ecu is good. If I can fix the hot start issue I would feel much more confident in the car.
                        Arbor press ftw
                        Two bolts ya chump!!!
                          In addition to the cv (moot point) The brake lines, abs sensor, parking brake cable, shock, spring, and sway bar end link.
                          Not to mention the difficulty of doing the bolts on the passenger side (fuel filler neck)
                          In short, I did my last one in car.
                            The tools I listed are the way to go=) It would take you a half hour to do each side if you're moving at a good pace
                              Fab up a puller
                                I had an e30 that had an intermittent problem with the temp sensor for the ecu.  It would surge at idle when it warmed up and sometimes wouldn't start, it was the corrosion in the plug.  I cleaned up the connection and it was fine.
                                  I think I half assed tried this earlier but couldn't quickly find anything to clean the contacts with.
                                  What did you use?
                                    I think I used a pin or needle to scrape inside the female connector and then once I knew it worked I put some vaseline on the contacts with a Q tip to prevent future corrosion.  A tiny pin file would probably be good if you could find a small enough one.
                                      CLT issue fixed.
                                      Started by cleaning the contacts, then pulled the ecu connector and checked for continuity between the connector for the ecu and the sensor connector. Nada. Broken wires, b but where?
                                      Grabbed a spare harness (thanks @HipMF for hoarding m42 parts) and doubled checked my test method on a different harness and confirmed that the one in my car didn't have the cotton-nuity.
                                      Started pulling pieces off to gain access to the loom box under the intake and found that under the extremely brittle wire covering was a broken sensor wire, and one just barely hanging on. Patched those up and started it. CEL is gone! Car idled better than ever, and sadly there was another car in the way so I was unable to take it out to get it to temp and check the hot start issue. Though I doubt that still exists.
                                      Progress.
                                        Excellent!
                                          Picked up a little treat yesterday.
                                          I am not actually sure what car they will end up on though lol. The initial intent was for this, but I can adapt them to the perfect offset to run some good tires on the m52 car.
                                          4 fronts, 2 rears. I can run a staggered set or a square set.
