  3. Services Offered/Wanted
  4. Madison - compression / leak down test help
2 Posts 2 Posters 0 Views 1 Watching
  • C
    C
    cpandrewschmidt
    Hi all,
    Anyone around Madison that knows how to do a compression and leak down test?  Trying to determine if i have a bad headgasket on a 98 M3.  Thanks
    Andrew
      Disconnect the crank sensor, pull out a spark plug, stick compression tester in spark plug hole, crank engine, compare results to OEM range.  Do this across all cylinders.  *If you have a bad cylinder do a wet test.  Just add a few drops of oil to the piston before testing.
      Cylinder leak down - acquire cylinder leak down tester>pull the spark plug>put engine at TDC>insert cylinder leak down tester>zero gauge>add air pressure>measure loss> should be less than 20% air loss.
      That simple.
