813 Posts 31 Posters 0 Views 1 Watching
    Did you happen to try Bearings Inc? Worth a shot to try somewhere local.
      The deed has been done. I ordered with blunttech already. I'll keep them in mind for next time tho
        If you still need a couple more, they might be able to match something up for you.
          Aaaaaand blunt just said bmw screwed up and there aren't any in the states. Maybe I'll contact bearings,Inc afterall
            LOL. Man that sounds really annoying, I have been there, and I feel your pain.
              Doesn't look like bearings Inc can get it either. Gahh!!!
              • need4speed1299N
                need4speed1299N
                need4speed1299
                Is the part number 3341111431? If so, its a 28x58x16 bearing.
                Diagram-
                http://bmwfans.info/parts-catalog/E21/USA/320i-M10/1981/browse/rear_axle/side_shaft_wheel_bearings/
                If its a 30x58x16 though I believe the part number is 33411119994.
                  The one you linked is for a 320i, not a 323i. And yes, I've already had the part number from realoem for awhile now. [emoji14]
                  • need4speed1299N
                    need4speed1299N
                    need4speed1299
                    Dang.
                      You saved some cash getting the outer bearings from an industrial supplier, I think you are destined to pay full price from an auto supplier/dealer for the inners though
                        I didn't necessarily save cash on the outer bearings as those are common size and can be found anywhere. The inner bearing size is not common on the 323i, that's the trouble. We will see when I get them in from blunt tech
                          Got the secondary diff mount finished, powdercoated by Zach and the poly bushing pressed in. Turned out great!
                          • JeffJ
                            JeffJ
                            Jeff
                            What is the bearing part number and dimensions? And what brand is the number for? I can check with a couple suppliers and see if I can dig 2 of them up
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              Doesn't matter what brand it is really. Just has to be a deep groove ball bearing unt that is 30mm x 58mm x 16mm exactly. I found a company in China that has 14 Nachi brand bearings that,are made in japan. I ordered all of them and am reselling some to other e21 owners. Just waiting for them to arrive in mail.
                                Got my rear euro valance (formally kyle's) back from U-Spray all sandblasted and ready for some patchwork and welding to the car.
                                  Well I recieved one bearing from Blunt Tech so far as the other one was on backorder and BMW didn't tell him that. I should be receiving the other one on Tuesday tho. I also got all the japenese brand Nachi bearings from the company I found in China. They are the correct size as well and look to be great quality. Up there with Timken who we all know make great bearings as well. Finally able to move along with this rear end project.
                                    Hell yeah man! Glad to see you found the right bearings!
                                      New bearings and seals installed, broken bolts removed from stub axle, trailing arms cleaned and painted. Time to do a mock up of everything bolted together to figure out how much shorter I need the halfshafts to be.
                                      Figure I can cut an inch or 2 out of my bad halfshaft, put a metal pipe between it with some set screws to make an adjustable halfshaft. Then just play around with lengths until there is no binding in the cv joints for the entire trailing arm motion.
                                      Once the length is found I will then take the good half shafts to machine service in pewaukee to have them shortened and balanced.
                                        is the custom half-shaft length because of the diff or that euro half-shafts are unavailable?
                                          It is because of the diff. The medium case is wider than the small case, so the half-shafts need shortening. The euro and us models use the same half-shafts otherwise.
