  4. Turbo m52 obd2
Turbo m52 obd2
turbo go fast s
123 Posts 16 Posters 2.8k Views 1 Watching
    Looks good!  More pics!  What are the specs on the build?  Dyno graph?
    It has a to4e turbo in it right now I have a gt35 on stand by but I'm satisfied for now.
    arp head studs, Mls .140 headgasket
    M50 intake manifold, dinan throttle body
    two piece v band exhaust
    whatever wheels came with it.
    everything else is stock down to the radio
      Here is your pics, and I will be getting it dynoed soon I hope. Also does anyone know what rims these are the only have one marking.
        Those look like racing dynamics wheels. They should have markings on the back side.
          Like TJ said, they look to be Racing Dynamics. If not they could be Mille Miglias as well. Any plans for the front bumper?
            Like Earl said that TJ said, they look to be Racing Dynamics
              where are you going to put those gauges?
                I'm going to pull a wheel off later today and figure out what they are.
                I might take the m3 bumper off my 325is and put the one off this car on there.
                Partly because it will clear the intercooler better.
                or I may say no bumper and max cooling.
                  I like them up top because they are easy to see, but most likely I will be cutting out the sunglass holder move the obc down and move the radio where the obc used to be and put the gauges where the radio use to be. If that makes sense.
                    Well from what I have gathered the rims where made in the same place as Mille miglia, unless they are fakes but they say made in Italy and Fomb which is the place that makes Mille miglia.
                      whos tuning your car?
                        Me I'm using kwp2000 to tune the stock ecu.
                        Im probably going to switch to MS3
                        It just takes way to long to make tiny adjustments.
                          Awesome! What maf are you using? And cant you simply do partial flashes instead of sending an entire file?
                            Stock maf which is good up to 400 hp.
                            With the software I'm using you have to pull all the info off the ecu.
                            If there is a better way please guide me to the land of 1000hp lol
                            Its obdII and as far as I know rk tunes is the only people who will tune it, at a price of 1500 dollars. Which is a rip off, I'd rather put my money elsewhere.
                            This is just something fun to drive around town.
                              Well the HPX maf would be my next switch, along with e85. Tune it yourself! its a lot of fun. But I swear I read online about partial flashes with obd2. You are using romraider correct?
                              Odb1 tuning is very easy and much cheaper, but in your boat I would go MS3 if you aren't happy with the stock ecu. SOOO much easier.
                                Yes  you are correct I am using rom raider.
                                E85 is not out of the question.
                                  Changed some things up on the car.
                                  Had it dynoed at late model throttle.
                                  It was with a spare ecu with no revisions stock injectors and fmu 😮
                                  The numbers were right where I hoped they would be.
                                  It was 4th gear pull at 8 psi, the second run was right after so it was pretty hot.
                                  sorry I didn't save the semen sample to put on the sheet 😦
                                    Not bad for such low boost on a stock ecu😛
                                      Here I was thinking those numbers seem really low.
                                      That's about 60hp and 50 ft/lb more than stock (taking both from crank hp), assuming on the low side we have 10% drive train loss.
                                      I guess it's not that terrible now that I type that out.
                                        I bought and built the car for 2,500 dollars, I didn't have a boost controller installed otherwise mb could've hit 300
                                        185hp is the highest stock I've seen so an extra 60hp plus cool turbo noises. I'm sure I'll be back once I do a legit tune, with much higher numbers.
                                          To get an extra 50 hp out of a m52 n/a you would have to do cams intake headers chip m50 manifold and I still don't think you would be there.
