Turbo m52 obd2
Looks good! More pics! What are the specs on the build? Dyno graph?
Dont bother posting a dyno chart unless it is notarized, dated, scanned in on a 1200x1200dpi printer, and uploaded to a secure server.
Ignore the troll, welcome!
2200 hp at 4K I lost the sheet......
Hi, it's nice to have a new member pop up every once in a while. Where are you located?
Just north of Milwaukee.
It has a to4e turbo in it right now I have a gt35 on stand by but I'm satisfied for now.
arp head studs, Mls .140 headgasket
M50 intake manifold, dinan throttle body
two piece v band exhaust
whatever wheels came with it.
everything else is stock down to the radio
Here is your pics, and I will be getting it dynoed soon I hope. Also does anyone know what rims these are the only have one marking.
where are you going to put those gauges?
I like them up top because they are easy to see, but most likely I will be cutting out the sunglass holder move the obc down and move the radio where the obc used to be and put the gauges where the radio use to be. If that makes sense.
Me I'm using kwp2000 to tune the stock ecu.
Im probably going to switch to MS3
It just takes way to long to make tiny adjustments.
Awesome! What maf are you using? And cant you simply do partial flashes instead of sending an entire file?
Stock maf which is good up to 400 hp.
With the software I'm using you have to pull all the info off the ecu.
If there is a better way please guide me to the land of 1000hp lol
Its obdII and as far as I know rk tunes is the only people who will tune it, at a price of 1500 dollars. Which is a rip off, I'd rather put my money elsewhere.
This is just something fun to drive around town.
Well the HPX maf would be my next switch, along with e85. Tune it yourself! its a lot of fun. But I swear I read online about partial flashes with obd2. You are using romraider correct?
Odb1 tuning is very easy and much cheaper, but in your boat I would go MS3 if you aren't happy with the stock ecu. SOOO much easier.
