  4. Running Thread of the Daily: 325XI
107 Posts 14 Posters 2.0k Views 1 Watching
    This really helps with my work schedule. I don't have to brake into any corners.
      I demand to see launches!
      Haha, naw.
        The wheel set ups are 18x8 Et47 with 285s up front and 18x8.5 et50 255s in the rear.
        The story is Bimmer Bob (?) did an experiment to try and counter act the understeer the e46 chassis by putting big rubber up front. These were modified Evo wheels machined to an e46 set up.
        The seller said the car would get squirrely in the rear under hard braking.
        I wanted some quality wheels that could work on the m3 down the line.
            I hope it doesn't rain while you've got those on!  I still demand a launch video.
              Got these mounted, 255x35x18, on all 4 corners. Don't grip like the slicks but I'm not wrestling the wheel down rough roads anymore.
                Also, got a new drivers side window regulator installed.
                  Got a cylinder #5 misfire so I bought a new coil and OEM plugs. Plugs were previously replaced at 100k. Just turned 170k.
                    Plugs look to have lived a healthy life.
                    Id love to see the 255's on all four corners. Gonna make it to the cruise?
                      Oil change, vanos oil line and filter. 172,500 miles.
                        New headlight lenses and LED license plate lights.
                          How hard is it to install new lenses?
                            Pretty, pretty, pretty easy
                              17" wheels mounted today!
                              Running the old snow tires for now but I'll be swapping over the blizzaks I was running on the M3 2 years ago.
                                Went to the Dells this weekend for an indoor 24/7 softball tournament.
                                The Temps were pretty low outside.
                                On the way back in go to check the oil and notice it's higher than normal. In my head I'm like "here we go" as I reach over to check the oil cap and of course, a little bit of some baby diarrhea.
                                Drove it all the way home (Milwaukee) from the dells is no issue. Temp stayed rock solid but I was going easy on her.
                                I'll take a look at it today maybe it fixed itself.
                                In the meantime one can dream:
                                http://www.bimmerforums.com/forum/showthread.php?t=2042741
                                  Uh oh, head gasket go boom?
                                    #s54allthethings
                                      Haven't checked yet. I think it is gone though.
                                        After some research I am replacing the CCV system.  After taking it apart I found out that I have the old style dip stick tube that freezes up and backs up the system in cold weather.
                                        The pics:
                                        Mouse nest
                                        Old boot.  I have a new one.
                                        Someone put some silicone ATV stuff on that flapper thingy.
                                        Dirty injectors.  New o-rings coming soon
                                        32211180081389c723cd0b.jpg.
                                        Nasty.
                                        One leaf fell into the cylinder.  Luckily it blew it out with the air gun.
                                        Got some swag from my buddy!
                                        Got everything off and just need to clean it all up and run new vacuum lines.  The vacuum line to the exhaust and to the charcoal canister were both broken and very brittle.  Glad I'm getting into the motor and freshening it up.
                                        Now time for a beer and some GREEN BAY PACKER FOOTBALL!!!!
                                          flappy thing = DISA valve (i just learned that yesterday from helping visian with his m54 intake adventures.)
                                          what a mess of wires, hoses and pipes under those manifolds, eh?
