  4. Running Thread of the Daily: 325XI
107 Posts 14 Posters 2.0k Views 1 Watching
    What? Why? How does a 285 fit under a non-M e46? Please tell me you're not driving on the street with those tires.
      I like whats happening but im also not sure what business those tires have on the xi
        I demand to see launches!
          This really helps with my work schedule. I don't have to brake into any corners.
            Haha, naw.
              The wheel set ups are 18x8 Et47 with 285s up front and 18x8.5 et50 255s in the rear.
              The story is Bimmer Bob (?) did an experiment to try and counter act the understeer the e46 chassis by putting big rubber up front. These were modified Evo wheels machined to an e46 set up.
              The seller said the car would get squirrely in the rear under hard braking.
              I wanted some quality wheels that could work on the m3 down the line.
                  I hope it doesn't rain while you've got those on!  I still demand a launch video.
                    Got these mounted, 255x35x18, on all 4 corners. Don't grip like the slicks but I'm not wrestling the wheel down rough roads anymore.
                      Also, got a new drivers side window regulator installed.
                        Got a cylinder #5 misfire so I bought a new coil and OEM plugs. Plugs were previously replaced at 100k. Just turned 170k.
                          Plugs look to have lived a healthy life.
                          Id love to see the 255's on all four corners. Gonna make it to the cruise?
                            Oil change, vanos oil line and filter. 172,500 miles.
                              New headlight lenses and LED license plate lights.
                                How hard is it to install new lenses?
                                  Pretty, pretty, pretty easy
                                    17" wheels mounted today!
                                    Running the old snow tires for now but I'll be swapping over the blizzaks I was running on the M3 2 years ago.
                                      Went to the Dells this weekend for an indoor 24/7 softball tournament.
                                      The Temps were pretty low outside.
                                      On the way back in go to check the oil and notice it's higher than normal. In my head I'm like "here we go" as I reach over to check the oil cap and of course, a little bit of some baby diarrhea.
                                      Drove it all the way home (Milwaukee) from the dells is no issue. Temp stayed rock solid but I was going easy on her.
                                      I'll take a look at it today maybe it fixed itself.
                                      In the meantime one can dream:
                                      http://www.bimmerforums.com/forum/showthread.php?t=2042741
                                        Uh oh, head gasket go boom?
                                          #s54allthethings
