  4. The E46 M3 Journal
The E46 M3 Journal
536 Posts 34 Posters 0 Views 1 Watching
    Must feel great, and im glad you can now focus on the e30 again [emoji16][emoji1303]
      Getting codes, 170, 177, 175, 174, 79. Posting for reference.
      Going to clear them and see what happens.
        All codes are gone now. Put 50 miles on after I cleared them.
          Will you be making the picnic on saturday?
            After doing a little research I think I should put a new salmon color relay in for the SMG.
              If work doesn't have me booked up I should be able to!
              I have a sticker on the e46 that says my other car is an e30...
                SMG is giving me some trouble. Also, chasing a vacuum leak somewhere as I'm getting a 174 error code.
                Replaced SMG relay with two different new ones. Problem still exists. Once car gets hot, stop and go traffic/non-freeway driving, it slips into neutral and won't go back into gear.
                Getting a low pressure code from the SMG. Thinking the pump can't keep up when it is warm.
                My luck is seriously bad. I've been doing a good job on the good karma angle to life and still getting $#% * around by these damn bimmers.
                But when they work, all these headaches are worth it.
                  So what you are saying is you should have just done a manual swap? =P
                    Step 1: Buy e36
                    Step 2: Remove engine from e36
                    Step 3: Remove S54 from e46
                    Step 4: Install S54 in e36
                    Step 5: Burnouts
                      This is too true.
                      I have had many instances where I have thought of getting out of the car-hobby all together from frustration of working on things and dwelling too much about the mountain of receipts that would exist if I didnt immediately throw them away.
                      When its back together and im driving, all is well in the world.
                        This has been in my living room for a month...
                        Not driving the M3 much due to the SMG pump loosing pressure (I think), just random beat runs around town which have been a blast. Waiting for time to install the new pump and coil overs.
                          Got the intake manifold off and starting disconnecting the "new" smg hydraulic lines... need to pick up an 11mm line wrench.
                          • vng704V
                            vng704V
                            vng704
                            DrLeadFoot said:
                            Ordered some goodies.
                            Dunno if you have already but consider getting the reinforcements for the rear spring perch from rogue engineering. Can try garagistic at a lower price. http://www.rogueengineering.com/Rogue-Engineering-Rear-Spring-Perch-Reinforcement-E46_p_124.html
                              "New" SMG pump installed. Need to bleed and install intake manifold. Waiting until tomorrow to put the manifold on.
                                Front suspension installed as well as the Turner sway bar! Gonna need an alignment.
                                  So its probably going to handle pretty well or something
                                    That's what all the Internets say...
                                    I was able to get all this done today due to having my wife ( business partner) and associate outside with me. They had the laptops running and I was dictating emails and working on follow up for 7 hours. Between the 3 of us we got a ton done, be it work and bimmer!
                                      Slanging bolts
                                        The great wonders of technology lol. Gonna start tracking this with the fresh suspension goodies?
                                          vng704 said:
                                          Ordered
