  4. 135i build thread. I'm done hobcobbling posts together
109 Posts 16 Posters 2.2k Views 1 Watching
      bk335 said:
      Looking good.
      I had my car aligned at big bear last fall and whatever they adjust in the steering has been squeaking ever since.  It gets worse when the temp gets colder so I'm really stumped what squeaks.
      All they do is turn the inner tie rod... unless the boot got jammed up it shouldn't make any noise, although if that happens it usually doesn't make noise and/or the boot will correct itself.  If it's only when turning the wheel it's likely a lower balljoint or upper strut mount.
      • i_love_carsI
        i_love_carsI
        i_love_cars
        ran a data log with 19 psi targets from 3k to 7k last night. Some adjustment is in order to keep the boost target a little tighter and on track but it's starting to come together. Holding 18.6 when I let off throttle at 6750 rpm feels pretty good. Hopefully in the next week or two I will be in a spot to get on the dyno
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
        • bk335B
          bk335B
          bk335
          bk335 said:
          Looking good.
          That's exactly what I thought. I took the tie rods off a while back and greased the outer ball joints but that didn't help at all. It sounds like it's more where the rack and pinion meet.
          Slowest N54 in Wisconsin.
          • i_love_carsI
            i_love_carsI
            i_love_cars
            Got some early dyno results here that I'm pretty happy with but my car clearly has issues. Went to LMT this morning and put down roughly 420/470 with a boatload of timing problems. You can see the horespower just flatlines at 5k when it should just keep going up higher and higher to redline.  The torque and hp lines start to drop at the exact same point when timing starts getting pulled. There is a nasty drop at 5400 as well. Data logs have continued to show cylinder 1 as the primary culprit.
            So my plan is this:  figure out if I have a bad coil or injector on Cylinder 1, then get these new colder N20 plugs installed and working properly. Currently running a stock heat range plug and some of you know I tried the N20 plugs as recommended by Dzenno and PTF and I had some issues. I'm going to revisit that because they are a colder heat range and many other N55s are reporting success with them. Today I am going to swap coils between cylinders 1 and 2 to see if my timing issue shifts over to cylinder 2.
            Hopefully this will inform me enough to fix the car and resume tuning because at this point all I have is a cobb flash and a JB4 with high boost targets. No adjustments have been dialed in yet for AFR or timing bias in my jb4 map.
            #exhaustFlames
            http://vid1170.photobucket.com/albums/r526/wardjt1983/IMG_0127_zpsuzatlhtm.mp4
            2007 Z4MR
            2003 E39 M5
            2002 E46 M3
            2021 X5 40i
              Nice! Not bad numbers for an N55. Fix those timing corrections and you'll be much happier.
              Also, sweet flames breh.
              • i_love_carsI
                i_love_carsI
                i_love_cars
                I swapped ignition coils yesterday and no change. Cylinder 1 still giving wonky timing.
                Going to pull the plug and check the gap next I guess.
                2007 Z4MR
                2003 E39 M5
                2002 E46 M3
                2021 X5 40i
                  Did the n55 have injector issues?
                    Couldn't you have simply pulled a plug and checked it there instead of running back and forth to the dyno?
                    • i_love_carsI
                      i_love_carsI
                      i_love_cars
                      probably. it only takes a minute to swap them but I was at the dyno more to just get a base run of where I am currently at. Not really trying to solve world problems there. LMT had $50 pulls for the month of May which is a pretty good deal so I figured why the hell not.
                      2007 Z4MR
                      2003 E39 M5
                      2002 E46 M3
                      2021 X5 40i
                      • i_love_carsI
                        i_love_carsI
                        i_love_cars
                        not as widespread as N54 but it does happen.
                        2007 Z4MR
                        2003 E39 M5
                        2002 E46 M3
                        2021 X5 40i
                          Which backend flash are you running? E85?
                          I know my E85 backend flash drops all cylinder timing to 9-10° right when I hit full boost. From there, it tapers up to 12-13° advanced. Looks to me like all of your cylinders (except #1) aren't advancing timing.
                          • i_love_carsI
                            i_love_carsI
                            i_love_cars
                            agreed, there should be way more timing advance up top - what I don't know is just exactly what is throwing everything off. I am not ruling out the tune at this point either - I have a custom E85 BEF but I emailed Terry again about getting 98F0B posted. He never wrote a bef for that version of the n55 DME, which is frustrating. I sent him some data logs of what i currently have pleading with him because we talked 1.5 months ago and he said he'd write it but never did.
                            I would really like to have that in my pocket to upload and test with to see if it is just a tuning issue on the back end. Hopefully he responds today.
                            2007 Z4MR
                            2003 E39 M5
                            2002 E46 M3
                            2021 X5 40i
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              Here we fucking go. Terry got back to me today with a BEF for my DME version and VOILA. Car is running MUCH smoother and these logs are totally stable now with the proper ignition advance. Not a single thing wrong with any of the hardware on my car. Everything was tuning-related.
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                              • i_love_carsI
                                i_love_carsI
                                i_love_cars
                                Ok people, I went back to the dyno today after the tuning adjustments. Now the car is running where I thought it should've been to begin with. Very happy and I finally feel like I can call this car "done" in my eyes. I know some people are pushing the N55 further but in my opinion that's a $$$ rabbit hole that just isn't worth going down. At some point I'm going to sell this car and move into V8 territory.
                                475 whp / 477 wtq on E50 was my best pull today. The power band looks fantastic and I really couldn't be happier, especially knowing that I put all the parts on the car together myself and shit isn't blowing up.
                                First 2 pulls were back at 21 psi same as what I had last week when I was making 420. When those looked clean I upped the targets to 23 psi in the midrange. Pull 3 had intake temps of 120 degrees so I had their dyno tech spray the engine down a bit before the 4th pull and picked up an extra 9 hp / 8 tq on the 4th pull.  23 psi in the midrange gave a really nice power increase between 4k and 5500 as you can see.
                                2007 Z4MR
                                2003 E39 M5
                                2002 E46 M3
                                2021 X5 40i
                                  That torque after turning up the boost!
                                  I hope you're not still running lean. I saw your post on N54tech and looked at your logs.
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    So far so good. N55's do run a bit more on the lean side anyway but my AFRs pull down to about 12.9-13.1 above 5400 rpm. Terry looked at logs I emailed him and said it looked fine but with the timing on the BEF I just don't see a 12.3 AFR happening without PI or meth. I don't think it's going to be anywhere near dangerous enough to lean out at those numbers, though.
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                      If you're comfortable with it, that's all that matters. If I were you, I'd richen it up with by adjusting the scalers in the BEF.
                                      • i_love_carsI
                                        i_love_carsI
                                        i_love_cars
                                        I could get behind that logic
                                        2007 Z4MR
                                        2003 E39 M5
                                        2002 E46 M3
                                        2021 X5 40i
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          After digging around a bit today, I'm deciding that I'm gonna stick to my guns with the current tune as planned. I sent the logs to Terry and he just got back to me and says the afr looks fine. His direct words were actually "the richer AFR on n55 leads to more misfires and headaches, which is why it's set where it is". You tune higher boost on these turbos to low 12's AFR you will actually misfire at higher rpm's. It goes against the convention of every other car I've ever owned being happy at about 12.3 AFR, but PURE's shop cars have the same thing so I'm not gonna worry about it.
                                          Here is one of their charts and the AFR is very similar to mine. They run about 12.9 sooner but above 4500 rpm they are still at 13.3 or so:
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
