  4. 135i build thread. I'm done hobcobbling posts together
109 Posts 16 Posters 2.2k Views 1 Watching
    i_love_cars said:
    Whaaaat dude we need to caravan for that. There's no way my tune will be ready because dzenno is on vacation from April 9 through the 18th or something but I would totally go along to watch some cool cars.
    Beyond redline is hours away from me so I will have to pass but let me know what your plan is for the 30th
    Are you going?
    My friends and I are getting a hotel on Thursday night in Milwaukee (heavy drinking will probably be involved). Then we will drive 3.5 hours to a hotel in Champaign, IL for Friday and Saturday night. The airstrip races are about 20 minutes away from our Champaign hotel.
    • i_love_carsI
      i_love_carsI
      i_love_cars
      i didn't even know it was happening until you mentioned it. It's a hell of a hike. I was hoping it'd be closer and not so far south of chicago.  ;(
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
      • i_love_carsI
        i_love_carsI
        i_love_cars
        update: cobb flash is done and starting on jb4 map now. The BEF used in the videos taken above is hitting about 11 psi at 3k and getting up to 18 at 5500 and holding that to redline. For JB4 will be initially on 17 psi across the board from 3k rpm, and with a couple tweaks hopefully end up closer to 20 psi across the board on e50.
        I still can't believe how well this turbo holds boost at higher rpm. It's such a staggering difference from a stock N55 turbo which just utterly ran out of breath at like 5200. This thing hits 6500 and keeps going.
        if this shitfuck wisconsin weather would just...fix itself...
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
        • i_love_carsI
          i_love_carsI
          i_love_cars
          installed kW street comfort coilovers this weekend and just had Big Bear Tire do the adjustments today. H&R springs were a cheap way to prove whether or not I could get in my driveway if I lowered my car, but I definitely think I waited too long to get these coilovers. The ride height is so much more even now between front and back. Before the front was sagging over the tire and the back was 1.5" above the tire. Not to mention having springs that are matched properly to the damper in a proper coilover setup has dramatically improved ride quality.
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
            Looks good man!
            • bk335B
              bk335B
              bk335
              Looking good.
              I had my car aligned at big bear last fall and whatever they adjust in the steering has been squeaking ever since.  It gets worse when the temp gets colder so I'm really stumped what squeaks.
              Slowest N54 in Wisconsin.
              • i_love_carsI
                i_love_carsI
                i_love_cars
                interesting, I actually have a bit of a creaking noise when i turn the wheel at low speed/stopped as well, but it started about 2 weeks after having the car back together from the turbo install. I haven't been able to definitively figure it out either. I"ve re-torqued everything but it sounds like the steering boots are pulling.
                shoulda taken it back to them. They do a lot of track setups for people I know and I've had all 4 of my cars there and never any issues. Jason is usually really good. Our goal should be to get our steering problem fixed before the next WIBimmers meet, otherwise Snap will just have more ammunition to make fun of us with as he lashes out at others who have functioning cars because he refuses to man up and buy a 335.
                2007 Z4MR
                2003 E39 M5
                2002 E46 M3
                2021 X5 40i
                    bk335 said:
                    Looking good.
                    All they do is turn the inner tie rod... unless the boot got jammed up it shouldn't make any noise, although if that happens it usually doesn't make noise and/or the boot will correct itself.  If it's only when turning the wheel it's likely a lower balljoint or upper strut mount.
                    • i_love_carsI
                      i_love_carsI
                      i_love_cars
                      ran a data log with 19 psi targets from 3k to 7k last night. Some adjustment is in order to keep the boost target a little tighter and on track but it's starting to come together. Holding 18.6 when I let off throttle at 6750 rpm feels pretty good. Hopefully in the next week or two I will be in a spot to get on the dyno
                      2007 Z4MR
                      2003 E39 M5
                      2002 E46 M3
                      2021 X5 40i
                      • bk335B
                        bk335B
                        bk335
                        bk335 said:
                        Looking good.
                        That's exactly what I thought. I took the tie rods off a while back and greased the outer ball joints but that didn't help at all. It sounds like it's more where the rack and pinion meet.
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          Got some early dyno results here that I'm pretty happy with but my car clearly has issues. Went to LMT this morning and put down roughly 420/470 with a boatload of timing problems. You can see the horespower just flatlines at 5k when it should just keep going up higher and higher to redline.  The torque and hp lines start to drop at the exact same point when timing starts getting pulled. There is a nasty drop at 5400 as well. Data logs have continued to show cylinder 1 as the primary culprit.
                          So my plan is this:  figure out if I have a bad coil or injector on Cylinder 1, then get these new colder N20 plugs installed and working properly. Currently running a stock heat range plug and some of you know I tried the N20 plugs as recommended by Dzenno and PTF and I had some issues. I'm going to revisit that because they are a colder heat range and many other N55s are reporting success with them. Today I am going to swap coils between cylinders 1 and 2 to see if my timing issue shifts over to cylinder 2.
                          Hopefully this will inform me enough to fix the car and resume tuning because at this point all I have is a cobb flash and a JB4 with high boost targets. No adjustments have been dialed in yet for AFR or timing bias in my jb4 map.
                          #exhaustFlames
                          http://vid1170.photobucket.com/albums/r526/wardjt1983/IMG_0127_zpsuzatlhtm.mp4
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                            Nice! Not bad numbers for an N55. Fix those timing corrections and you'll be much happier.
                            Also, sweet flames breh.
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              I swapped ignition coils yesterday and no change. Cylinder 1 still giving wonky timing.
                              Going to pull the plug and check the gap next I guess.
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                                Did the n55 have injector issues?
                                  Couldn't you have simply pulled a plug and checked it there instead of running back and forth to the dyno?
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    probably. it only takes a minute to swap them but I was at the dyno more to just get a base run of where I am currently at. Not really trying to solve world problems there. LMT had $50 pulls for the month of May which is a pretty good deal so I figured why the hell not.
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                    • i_love_carsI
                                      i_love_carsI
                                      i_love_cars
                                      not as widespread as N54 but it does happen.
                                      2007 Z4MR
                                      2003 E39 M5
                                      2002 E46 M3
                                      2021 X5 40i
                                        Which backend flash are you running? E85?
                                        I know my E85 backend flash drops all cylinder timing to 9-10° right when I hit full boost. From there, it tapers up to 12-13° advanced. Looks to me like all of your cylinders (except #1) aren't advancing timing.
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          agreed, there should be way more timing advance up top - what I don't know is just exactly what is throwing everything off. I am not ruling out the tune at this point either - I have a custom E85 BEF but I emailed Terry again about getting 98F0B posted. He never wrote a bef for that version of the n55 DME, which is frustrating. I sent him some data logs of what i currently have pleading with him because we talked 1.5 months ago and he said he'd write it but never did.
                                          I would really like to have that in my pocket to upload and test with to see if it is just a tuning issue on the back end. Hopefully he responds today.
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
