  4. This isn't an e36 M3 build thread: Build Thread
23 Posts 12 Posters 0 Views 1 Watching
    Are you planning on running the stock gear ratio? Now might be a good time to consider a different diff altogether.
    • StriggityStrackS
      StriggityStrackS
      StriggityStrack
      I wasn't planning on changing the final drive ratio but since you mentioned it I took a look at the regulations for the Street Touring class.. " K. Limited Slip Differentials STS, STF: No limited slip differentials are permitted except for factory standard viscous coupler type units." Well shit...
        Didn't the auto come with a shorter rear end... which is still technically a factory standard VLSD.
        • StriggityStrackS
          StriggityStrackS
          StriggityStrack
          I don't know about the auto. I have a manual. I may still be confused about the what type of LSD I have. I figured it wasn't a viscous LSD because it has clutch packs.
          • StriggityStrackS
            StriggityStrackS
            StriggityStrack
            These rules are confusing. So I found the classification sheet and I have no clue what any of this means because there is no legend. This says that my car is STU eligible (I have no clue what that means) but now that I look at the rules it has this exception " STX, STU, STR: Only standard (as defined in Section 12) limited slip differentials (LSD) are allowed on AWD vehicles. For AWD vehicles that did not come with any type of limited slip differential (including center differential or transfer case), a single aftermarket mechanical LSD may be added. 2WD vehicles may use any mechanical LSD unit". 56fe85fa83e334-1-20169-29-06AM.thumb.jp
              That's why I gave up and just put whatever I wanted to on my car. They can toss me in whatever auto x class they feel like, I'm there to have fun and race against myself.
                These are the new regs
                http://www.scca.com/pages/solo-cars-and-rules
                  Sorry, my mistake.  They are mechanical LSD's.  I am pretty sure between the auto and manual they are interchangeable.
                  • StriggityStrackS
                    StriggityStrackS
                    StriggityStrack
                    You are completely right. I guess I just had a freak out moment there. lol.
                      Yikes, I hope my diff doesn't look like that, now I'm going to worry...
                      I'd think about reinforcing the RTAB pockets if you are planning on running super stiff RTAB bushings, the extra stresses on the mounts can cause the bungs to pull out, it's rare but can happen. AKG makes a nice weld-in reinforcement plate for about 30 bucks for the pair and is good insurance while you're in there.
                      Nice car by the way! I just realized there are two Joe's with E36 M3's on here haha
                      • StriggityStrackS
                        StriggityStrackS
                        StriggityStrack
                        I was actually debating on buying them and had them in my shopping cart until I last minute pulled them out. I don't have a welder in my garage and the cars not going anywhere until I get everything back together.
                        And thanks man.
                          Get out there and have fun. Autox is a high intensity 10/10ths car rush for roughly 40-60 seconds a run depending on the course layout and your skills, and then hanging out with car folks for a while until your next fix. If you decide that you really want to get serious then you can buy/build for a particular class. The SCCA events at Miller Park in Milwaukee are a great opportunity to watch and meet a number of national level class winners, and get a sense of how good some folks really are at this. Get rides if you can, if the event does fun runs later in the day.
                          DE events, open track days, and the jump to w2w ramp up the costs in prep and consumables and take the addiction to a different level. You're not running at 10/10ths since the speeds and consequences of mistakes are much higher and you're dealing with other folks on track. Different rush, all good.
                            Bingo. This is my plan. Go to an auto-x or two and just have fun.
                            I know the mods I've done probably put me in a class way above my skill level. Oh well, I'll still have a blast.
                            • StriggityStrackS
                              StriggityStrackS
                              StriggityStrack
                              Participation points.
                              Things happened
                              Stuff got powdercoated
                                Looks great!
                                  Now we can cruise!!!
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Looks great. nice work!
                                      Damn, car looks awesome. Rear end came out great.
