  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
    Even with my subframe out of the car, getting the 4 bolts to line up were a pain in the ass. Maybe buy/install a stud kit?? Other than that, +1 to what snap said.
      just think about the goofy-ass angle that is needed to get the diff out. you need to replicate that to get it back in. also, you might want to try rotating the driveshaft to a new position to change the bolts from an X to a +, for example. can't remember if one arrangement makes it better or not. probably whichever arrangement allows for up/down movement of the rear joint on the driveshaft.
        ^ could even loosen up the CSB if needed. Don't forget the preload when re-tightening
        • CMartC
          CMartC
          CMart
          I got so frustrated I removed the driveshaft and exhaust to make it easier.
          Today is a new day. If it's all I get done I'll be happy.
          Excursion 7.3
          E30 LS1
          • CMartC
            CMartC
            CMart
            Whew - So I took two longer bolts and hung the diff by the two rear holes that gave it room to move. Got the front two lined up, then brought the back two up and replaced them with the stock bolts. Was not easy, but I am happy its done. Going to get the driveshaft back on and start working on a few other things.
            Big projects right now are:
            shortening up the wiring
            replacing the whole interior (switching from beige to black)
            Redoing the brake lines
            Relocating the oil filter housing
            Hooking up the power steering
            And probably a lot more.
            Good news is I know it runs, and with the new diff it will be a lot more fun to drive.
            Excursion 7.3
            E30 LS1
              4.10 with m62? can't wait to see that.
              • CMartC
                CMartC
                CMart
                4.10 with the M62 was dumb. Hit the gas and it spun the wheels.
                Swapped it for a 2.93 medium case LSD. After I pulled the 4.10 I found it was non LSD so it will be all around better.
                Excursion 7.3
                E30 LS1
                  oh your post read like you pulled the 2.93 and put back the 4.10, my bad!
                  • CMartC
                    CMartC
                    CMart
                    Rewelded the transmission mount for more strength and ran the wiring through the firewall today to clean things up.
                    I'm a little confused on the power steering routing...
                    Basically the routing for me will be:
                    reservoire -> power steering pump  -> rack  -> cooler -> reservoire
                    The smaller bolt on the E30 power steering rack. Is this the pressurized fluid going in or the fluid coming out?
                    Excursion 7.3
                    E30 LS1
                      your routing is correct. not sure if you really need the cooler, though, not all e30s had them. its not particularly hot around here...
                      from realoem, it looks like
                      M16 (larger) banjo bolt is on the supply line from the res to the pump
                      M14 (smaller) banjo bolt (both ends)  goes from the pump to the rack
                      then
                      M16 (larger) banjo bolt returns from the rack to the res. with the cooler in there for cars that came with it.
                      • CMartC
                        CMartC
                        CMart
                        Well I don't NEED the cooler, but the return end of the reservoir has a fitting that goes directly into the cooler so its free to have one and it would cost me to not so I figured why not.
                        Excursion 7.3
                        E30 LS1
                        • CMartC
                          CMartC
                          CMart
                          I found the in vs out on the reservoir and I think I have it figured out now. I may have to get some high pressure banjo lines made (any suggestions on where?)
                          This shows the cooler ends I was referring to:
                          Excursion 7.3
                          E30 LS1
                            I've had custom lines done at Hartland Service. Excellent job, done right while I waited, and very good prices.
                            • CMartC
                              CMartC
                              CMart
                              Just called them. They seem great - looking forward to throwing some business their way.
                              Excursion 7.3
                              E30 LS1
                                They're awesome. A few friends and I have been using them for years. They actually custom made me braided stainless brake lines for much less than you could buy them anywhere. I need to see them soon to have power steering lines made as well.
                                • CMartC
                                  CMartC
                                  CMart
                                  Well I was able to get creative with some extra lines.
                                  Power steering is hooked up and the oil filter is relocated.
                                  Before picture - notice how cramped (the oil filter) that would be with the brake booster relocation
                                  And now:
                                  Now I am going to redo all the brake lines (in the mail), install the coils and BBK while I am at it.
                                  I got the wiring moved into the interior so that is progress, but it still needs to be cleaned up. Whole interior back in. I'll probably take the motor/trans out to redo the brake lines and clean everything up while its out.
                                  Then throw some miles to work any potential gremlins out, put it up for sale, and start work on the LS M3.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    Here is a better picture of the only place the remote oil filter fit with everything attached.
                                    Much better here now and still easy to access for oil changes.
                                    I'll probably wait until next week to pull the motor so more updates to come then.
                                    Excursion 7.3
                                    E30 LS1
                                      Awesome work!
                                      • CMartC
                                        CMartC
                                        CMart
                                        Motor is back out to redo the brake lines.
                                        Looking forward to getting the motor back in, it will be much cleaner than the last setup. I also painted the remote booster reinforcement plate.
                                        Excursion 7.3
                                        E30 LS1
                                        • CMartC
                                          CMartC
                                          CMart
                                          Brakes system is done.
                                          Engine and trans are back in.
                                          Headers were ceramic coated and installed.
                                          Cant decide if I should do the coils now so I only have to bleed once or down the road. Other than the height change will installing the new coils/knuckles change the steering to the point where I'll need an immediate alignment?
                                          Excursion 7.3
                                          E30 LS1
