  4. '88 E30
'88 E30
    Savebigmny, add me.
      are you going to do 6 or more track days every year? adjustable coilovers.
      if not, just pick a tried and true setup and roll with it.  I'd say Koni/IE3 or Koni/H&R is failproof.
      Intentions are to get into some more auto x events. Car will be DD'd in the summer on occasion but I'm not relying on it as my only mode of transportation.
      Only reason I was after adjustability is I can choose my spring rates and adjust the front end of the car for height
      Adjustability sounds very nice at this point
        Savebigmny, add me.
        Snapchat?
          BC Racing coilovers man
            Savebigmny, add me.Sent from my 831C using Tapatalk
            Snapchat?
            Yes
              Control arms are on & skid plate is mounted. Tomorrow going to lower the engine back into the subframe
              Can someone verify that these are torqued to a measly 30ftlbs??
              This much room between the pan and skid plate. Should take some decent hits if necessary
              Can easily get the drain plug as well
              Led light added the lined look, it's not actually there
              Hopefully I can get this heap in tomorrow 9b729180ae64ccccd0753c5d1cc56fda.jpg
                not 'if necessary'. its going to happen. probably a lot. and it will be terrifying the first couple times. WHACK!
                my favorite was roads and alleys that were crowned enough that the skid plate just scrapped along them the whole way.
                  Engine is now back to where it should be bdcb3f1bfe5a77e5cd8d20254a8566fe.jpg
                  Everything under the front of the car has been torqued. Just need to get struts/brakes in the front.
                  Didn't get around to the rear subframe yet, but I imagine I will swear at it a lot
                  • i_love_carsI
                    i_love_carsI
                    i_love_cars
                    looks good Mitch, would like to see this at the E30 picnic
                    2007 Z4MR
                    2003 E39 M5
                    2002 E46 M3
                    2021 X5 40i
                      Thanks Man, I would love to go to the picnic as well but I think I am being dragged to automotion (unfortunately) by my gf.
                      I'll report on all the flat brims, diesel trucks and Chevy cruzes I see
                        This is coming along nicely. Looks clean!
                          just caught the dust scribble..nice.
                            I am trying a new technique of writing down my feelings Dan. This is how I express myself.
                            Some people build bird houses, I scribble on dusty cars
                            ^this is a joke btw- I wrote that on my car like 9 beers deep haha
                              Just ordered some hawk pads, stainless front lines, Motorsport hardware stud conversion & new diff plugs (mines weeping a bit of fluid) I think I had put royal purple in it last year...any recommendations for diff fluid? Weight?
                                I had redline 75w90 in mine, no issues to report for the >5,000 miles I put on the car since I did it. I will be putting the same thing in the M next weekend. How did the Red46 skid plate fit? I have the m42 one sitting in a box since it hasn't really been a priority on the e30 job list lately
                                  Not sure if you guys are changing transmission fluid as well, but I have found that red line fluid works infinitely better in bmw transmissions over royal purple.
                                    red46 plate fit well. depending on the shape your core support is in, it goes on with 7 bolts. 2 longer ones in the rack & 5 thru the core support
                                      IIRC i may have put RP ATF (syncromax?) in it because that's all i could get on somewhat short notice before i put the trans in last year. Either way, trans shifts fine as far as I can tell, no obvious signs of crappy shifting/
                                      For the diff im probably gonna go Redline 75w90, I believe I have RP 75w90 in there now (place I went to sold RP, can you tell)
                                        Royal purple has not helped my zf trans at all. Feels like the synchros aren't there sometimes. (From what I remember)
                                          pads I went with HT-10 and Street Race
                                          78mm motorsport hardware
