  4. '88 E30
'88 E30
savebigmoney
    My favorite was the PB Blaster one=)
    That one and the one regarding finally giving up on tech tip numbers.
    .....and the spray cans on the shelf.
    ...and the one about keeping old hardware.
    Many of these hit home apparently lol.
      Got the subframe in & steering rack
      Subframe needed some persuasion
      Steering rack needed a tad of persuasion too. E36 rack/tierods
        Tomorrow I'll be taking the rear most subframe bolts out again so I can get the ST sway bar on. Also going to try and get the control arms on
          Sway bar is mounted and torqued
          Got the control arm offset bushings on (pain in the ass because of the taper)
          I'll most likely pop those in tomorrow. After they are in I'll be dropping the engine back onto the subframe so I can get the support bar out of the way. Then it'll be on to the rear subframe
          For anyone who was curious about the ST sway bar hardware here's a picture. Way beefier Than the oem stuff. Washer has a gap due to this shit being 28 years old
          Also does anyone have any use for these rear trailing arm sway bar mount reinforcements (and bushing brackets)?? I already had these reinforcements.
          If you pay postage they're yours
            Looking good!
            Smart move to mark the orientation on the lollipops before install on the control arms.
              It's official. I have no idea what to do for suspension. I can't make up my mind
                are you going to do 6 or more track days every year? adjustable coilovers.
                if not, just pick a tried and true setup and roll with it.  I'd say Koni/IE3 or Koni/H&R is failproof.
                  Savebigmny, add me.
                    Intentions are to get into some more auto x events. Car will be DD'd in the summer on occasion but I'm not relying on it as my only mode of transportation.
                    Only reason I was after adjustability is I can choose my spring rates and adjust the front end of the car for height
                    Adjustability sounds very nice at this point
                      Savebigmny, add me.
                      Snapchat?
                        BC Racing coilovers man
                          Savebigmny, add me.Sent from my 831C using Tapatalk
                          Snapchat?
                          Yes
                            Control arms are on & skid plate is mounted. Tomorrow going to lower the engine back into the subframe
                            Can someone verify that these are torqued to a measly 30ftlbs??
                            This much room between the pan and skid plate. Should take some decent hits if necessary
                            Can easily get the drain plug as well
                            Led light added the lined look, it's not actually there
                            Hopefully I can get this heap in tomorrow 9b729180ae64ccccd0753c5d1cc56fda.jpg
                              not 'if necessary'. its going to happen. probably a lot. and it will be terrifying the first couple times. WHACK!
                              my favorite was roads and alleys that were crowned enough that the skid plate just scrapped along them the whole way.
                                Engine is now back to where it should be bdcb3f1bfe5a77e5cd8d20254a8566fe.jpg
                                Everything under the front of the car has been torqued. Just need to get struts/brakes in the front.
                                Didn't get around to the rear subframe yet, but I imagine I will swear at it a lot
                                • i_love_carsI
                                  i_love_carsI
                                  i_love_cars
                                  looks good Mitch, would like to see this at the E30 picnic
                                  2007 Z4MR
                                  2003 E39 M5
                                  2002 E46 M3
                                  2021 X5 40i
                                    Thanks Man, I would love to go to the picnic as well but I think I am being dragged to automotion (unfortunately) by my gf.
                                    I'll report on all the flat brims, diesel trucks and Chevy cruzes I see
                                      This is coming along nicely. Looks clean!
                                        just caught the dust scribble..nice.
                                          I am trying a new technique of writing down my feelings Dan. This is how I express myself.
                                          Some people build bird houses, I scribble on dusty cars
                                          ^this is a joke btw- I wrote that on my car like 9 beers deep haha
