Guilty pleasure
Haha it has an air filter now. It's fresh engine break in so I'm using 10-30 brad penn
Fic 2150cc
Buschur double pump
8an lines
Pte6766 bb
Tial 44 mm gate
Fp5r 11r cams
Evolution dynamics ported head, 1mm stainless valves
It's a 2.1 super long rod
Manley crank
Carillo rods
Cp pistons 11:1
compression
Hayes trans with 4.10 final drive
Hayes t case
Hayes diff
Still on stock axles -
2.1 super long rod
you keep telling yourself that.
Dyno #'s?
I honestly have only changed the oil and drove it around the block. Need an idle valve I'm getting this weekend. Then I'll street tune it on wastegate pressure, then bring it to the dyno for mbt tuning
Should easily clear 900whp on e85, but I'm shooting for 6-700whp daily.
Lmao. To clarify, it's using a 4g64 block with is 6+mm deck height, and larger bore. So, stock rods are 150mm, long rods are normally 156, and these are 162.
Ill be be shifting at 9500 or so, but I can reliably rev to 11k+ if I had a dog box and dry sump lol
You should probably buy a shitbox Corolla to get you to work.
The guy before you did the work and didn't bother to dyno it?
Still have lots of cars. 02 wrx wag, 91 s13, 4x e30's(2 running and driving ha) have my dually flat bed Isuzu.
But im not kidding. i bought an evo to drive every damn day and that's what it's gonna do. my drive to work is one of my favorite things, and this car will be made for that exactly.
Did you just use the word "reliably" in reference to an Evo? We'll see.
Haha it relative. It technically is more reliable versus a shorter rod. This thing has like 1.8 rod ratio lol.
But i put 7k miles and 20+ launchs and 3 sets of tires thru my last evo(which had stock trans and t case) and it never broke a sweat. By far the most reliable car I've owned. It was also at 140k when I traded.
Where'd you find it?
Wisconsin evo owners. Dude traded an evo motor swapped rwd mustang for it, drove to Texas for it, and then I traded my car for it before he even drove it lol. He's having his second kid now and needed something reasonable.
It's been a week, any updates on the new Evo?
It's almost as though you're bearing bad news.
I see what you did there
