  4. Guilty pleasure
Guilty pleasure
79 Posts 24 Posters 1.6k Views 1 Watching
    I honestly have only changed the oil and drove it around the block. Need an idle valve I'm getting this weekend. Then I'll street tune it on wastegate pressure, then bring it to the dyno for mbt tuning
    Should easily clear 900whp on e85, but I'm shooting for 6-700whp daily.
      you keep telling yourself that.
      Lmao. To clarify, it's using a 4g64 block with is 6+mm deck height, and larger bore. So, stock rods are 150mm, long rods are normally 156, and these are 162.
      Ill be be shifting at 9500 or so, but I can reliably rev to 11k+ if I had a dog box and dry sump lol
        Did you just use the word "reliably" in reference to an Evo? We'll see.
        • andyhundleyA
          andyhundleyA
          andyhundley
          You should probably buy a shitbox Corolla to get you to work.
            The guy before you did the work and didn't bother to dyno it?
              Still have lots of cars. 02 wrx wag, 91 s13, 4x e30's(2 running and driving ha) have my dually flat bed Isuzu.
              But im not kidding. i bought an evo to drive every damn day and that's what it's gonna do. my drive to work is one of my favorite things, and this car will be made for that exactly.
                Haha it relative. It technically is more reliable versus a shorter rod. This thing has like 1.8 rod ratio lol.
                But i put 7k miles and 20+ launchs and 3 sets of tires thru my last evo(which had stock trans and t case) and it never broke a sweat. By far the most reliable car I've owned. It was also at 140k when I traded.
                  This one is 70k miles Texas 03. My last one was Minnesota 140k mile 06, but this has all 9's parts anyways, minus mivec
                    Where'd you find it?
                      Wisconsin evo owners. Dude traded an evo motor swapped rwd mustang for it, drove to Texas for it, and then I traded my car for it before he even drove it lol. He's having his second kid now and needed something reasonable.
                        It's been a week, any updates on the new Evo?
                          It's almost as though you're bearing bad news.
                            I see what you did there 😆
                              Seize the day!
                                Lack of updates has spun my thoughts on Evo ownership.
                                  Lol
                                    Guys, I'm dying over here.
                                      Wow, he's pretty chipper for having a fucked 4g63.
                                        4 active posters on here and the only thing you guys have to post about is a broken mitsu turd haha.
                                        Spun a rod bearing first time driving it more or less. Retard who assembled the block didn't check the main clearances, just believing that the manley crank was good because it was new. They were all over the place.
                                        Oh well. At least it happened under zero load, and everything is just fine. sending the crank out tomorrow for grinding and re-nitriding, and same with the rods. Block is perfect, and so are the bores. Machine work was good, just a stupid PO who assembled. it.
                                        He also put the floater plate on the QM twin disc on backwards LOL. Which is amazing to me, how do you buy a new clutch like that and install it wrong? Its literally brand new, looks like it never had a single pull done.
                                        Give me another couple weeks and hopefully all is well!
                                          honestly tho, around 3 hours and I had the thing completely taken apart, and this was outside, birds chirping, while drinking beer on a Saturday, in march, with a t shirt. It was freaking great.
