  3. BMW Discussion
  4. e30 rims advice
e30 rims advice
30 Posts 9 Posters 498 Views 1 Watching
    Centras.
    • C
      C
      cpandrewschmidt
      That looks good HipMF.  Size rim, tire, offset?  Any fender rolling or spacers?
        whats your budget? has a lot to do with rim selection.
        sizes? really no reason to go wider than 7.5" for an everyday car. 15x7, 15x7.5, or 16x7.5 are good options.
        some of my top favorites for those size: all of these fit without spacers or fender modifications.
        e30 Euroweaves (15x7 et 24)
        Ronal LS (15x7.5 et 25)
        Ronal Turbo (15x7 et ??)
        Borbet type C or type A (16x7.5 et30)
        Azev type A (16x7.5 et20)
        Any BBS weave style rim. RX, RZ, RS, RA (come in 15x7 to 16x7.5 sizes)
        If you must pickup a set from ebay, the RS replicas look nice. with a size like 15" or 16" i wouldnt be too worried about bending as you still have a lot of tire. make sure its somewhere around et20 or et25 and stay away from anything 9" wide.
        as snap said, spacers work but are annoying. they get stuck to the hub, have to come off if you run winter/summer wheel setups, need longer lugs, blah blah blah better to avoid them.
          It all depends on what look you're going for. Do you want it to be track inspired or all stance car fanboi'd out?
          • C
            C
            cpandrewschmidt
            Here are some pics of the car.  Not the best, but best I found on my phone.  This will give you sense of the ride height.  Front is too low, I'm going to raise about 3/8" in the spring.  I don't track or do anything aggressive with the car.  Just cruise around on nice days.  I just want a classic rim like the one pictured with a little lip to it.  Not looking to spend a lot as this isn't my daily driver and the car itself isn't worth BBS rims 😉   I was looking at the ESM's online.
            These seem OK too on craigslist.  They are 16x8" et25 on 205/45 tires https://rockford.craigslist.org/wto/5392345103.html  prices seems about right.  I was under the impression they wouldn't fit without rubbing?  I can't figure out all this offset stuff.
              I am assuming you have found the great wheel and tire fitment thread on r3v, thats your one stop shop on what combos fit.
              • C
                C
                cpandrewschmidt
                Hi Snap,
                I asked on there but haven't heard.  I'm sure people are sick of responding to the same questions.  Guess my question is will the craigslist ones I posted fit without rubbing or spacers?  16x8" et25 on 205/45  If those don't fit then I'll probably stick to a 16"x 7" or 7.5" rim if that's what people are recommending for just general street driving on a 16" rim
                  You should have no issues with that sizing and offset.
                    Those will fit without any issues.
                    IIRC, my girlfriend has those exact specs on her e30 with 195/40's.
                    • C
                      C
                      cpandrewschmidt
                      sweet, thanks guys
                        to me if you have to choose a specific, undersized tire which has worse performance than stock sizes to make a wheel fit, than the wheel doesn't fit.  performance here being grip, ride quality, and wheel protection. 195/40 = destroyed wheel if you hit a pothole. i think wheels should look good and i definitely like plus-sized stuff, but tires are just as important. earl, i'm not arguing this toward you, just the OP, so you can ignore me, and continue on with your stance-stance revolution.
                          Those tires weren't absolutely needed to make them fit so feel free to use wider ones=)
                          • C
                            C
                            cpandrewschmidt
                            Thanks, yes I'd agree 195/40 would be pushing the limit of what I'd feel comfortable with.  I do like a little stretch in a tire, not a ton.  I think  205/45 tires should be a good compromise to still have some "meat on the bone"
                            • C
                              C
                              cpandrewschmidt
                              well, didn't get that guy to a price I liked so moving on from the Craigslist rims.  Didn't love the white on them so unless the price was too good to be true I'm looking new.  Two other wheels I like have the following sizes:
                              15x8" et20 would like to run with a 205/50 R15 tire   or
                              15x8" et25 would run same size tire.  I like this wheel better but can't confirm anywhere if the offset would work.
                              Any help is again greatly appreciated!
                              • andyhundleyA
                                andyhundleyA
                                andyhundley
                                This is my car on 15x7 euroweaves with 205/55 tires. Hope this helps.
                                • C
                                  C
                                  cpandrewschmidt
                                  Thanks Andy.  I like 15"s  think they fit the car just right.  205/55 looks like a good amount of sidewall too without being too big.  You look lowered, are you?
                                  Yeah, it's the width of the rim I'm looking at (8") and then the different offsets that I don't really understand what that all means and what the limits are of what can or can't fit.  Thats what i need help with.
                                  For those who dont see above this is what I'm trying to figure out if they fit, two choices I like:
                                  15x8" et20 with a 205/50 R15 tire or
                                  15x8" et25 same size tire
                                    Fwiw I'm limited to a 15x7 wheel with a 205/50/15 Toyo in my race series with the e30. Offset in most rwd wheels in this size is +25. You can get a bit wider track with +15 wheel but it's a bit less common size in a 15x7. Some folks run spacers to get down to around +15 and the wider track width.
                                    Ideally I'd like a 15x8 wheel with +20 offset and 225 tires but such is racing. Trade off of course would be the added weight.
                                    The daily e30 has the stock 14x7 weaves and 195/60/14 in the summer and 185/70/14 snows. Went for cheap and functional.
                                    Tire rack website has good illustrations of offset to help you understand the principles.
                                    Given your two choices in the 15x8 wheels and the tire size the +20 offset would be the better choice, but other folks with more wheel/stance experience may have other insights.
                                      more pics here, but no specifics on the wheel size of offset 😃
                                      http://www.r3vlimited.com/board/showthread.php?t=295505
                                      If you haven't, look here. (link?)
                                      ...the different offsets that I don't really understand what that all means and what the limits are of what can or can't fit.  Thats what i need help with.
                                      Google it. The offset is a measurement between the center of the wheel, width-wise, and the wheel mounting surface, in millimeters. Lower = more poke, higher = more sunk. Check out the fitment thread(s) on r3v and pick whatever floats your dingy.
                                      • C
                                        C
                                        cpandrewschmidt
                                        ok, thanks guys for putting up with me, starting to get it.  So higher number = more sunk.  So, wouldnt the 15x8" et25 with the 205/50 R15 tire fit under the fender better than the et 20 with the same size tire?  More sunk into the car should have less chance of rubbing, correct? (but now i have to worry about clearing the caliper or strut?)  I would think pushing the rim out towards the exterior of the fender with a lower offset would lead to rubbing?  Is 5mm really enough difference that'll look stupid too sunk in the fender?
                                        Just seems like there's never a set answer on certain combinations.  Ugh......might just have to buy and try.  Seems rolling the fender is easier than caliper mods if they dont fit.  leaning towards the 15x8" et25.
                                          caliper clearance? thats a whole different ballgame and has more to do with rim style than offset. you shouldn't be running into any caliper clearance issues with any of the sizes or offsets that have been discussed here.
                                          15x8 et25 won't fit, you will be hitting the front strut.
                                          15x8 et20 won't hit the front strut, and should be fine with the fender with a 205/50 tire.
                                          as i said before, going wider than 7.5 inches is pointless (unless you have a specific wheel in mind, which it seems you dont), it just causes problems and 205 tires fit fine on a 7 or 7.5" wheel.
