  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Went to start it... no crank or starter sounds. SMG light is on. SMG fluid is topped off.
      Im guessing you had a jumper pack on it? Hate to ask the obvious questions but hows the battery voltage?
        My voltage meter is in my e30 trunk which has the whole e46 front end on top of it.
        The battery is about 1 year old and is an OEM bmw unit. It should hold a charge once fully charged up. Do that first and reassess. If that doesn't work, replace the starter with the original one. The one in the car now is a non-bmw re-man unit.
        Also need to look into properly getting the smg unit bled. The pump makes noise but doesn't go into gear.
        • T
          T
          tsweers89
          You will need to tow it to concours and have them bleed the system along with the clutch adaptation as you installed a new clutch. If the smg isn't in neutral it won't start. Also the hood needs to be closed or it won't start either.
            Good info there
              The car is in "0" but maybe the clutch isn't disengaged.
              The car should start with the hood open but you can't shift it into gear.
              I have 12.4 volts at the battery in the trunk and started.
              I jumped the starter with a screw driver and it works.
              I feel it's the key not talking to the car. There is a name for the system but it escapes me. I'll also make sure my slave shaft is sitting on the fork.
              I might be able to get a house call for bleeding the system as a mechanic owes me a favor.
                Got some new bolts for the v-brace, oil cooler line engine mount and new o-rings for the oil cooler.
                Most importantly got a new key. Hopefully this will start the car.
                  SMG isn't "talking" the the starter.
                    Is it still in "0" gear or is it in neutral?
                      Maybe if the starter would apologize for what he did then the SMG would talk to him again... if only the starter knew what he did wrong.
                        Doorman
                        Replace "starter" with "husband" and "SMG" with "wife"........
                          My issue:
                          The trans is physically in neutral and still in 0.
                          - Brand new key from BMW.
                          - 12.4 volts on the battery.
                          - The starter works fine and turns the engine over after testing it.
                          - Replaced the salmon relay with one I know was working.
                          - No blown fuses, #14 & #30 are good and tested good.
                          - Hydraulic fluid is filled topped off in the reservoir.
                          - Hood is closed.
                          - SMG shifter unit tested and is sending a signal.  (Flashes 0 and doesn't go into 1 or R)
                          - New clutch installed.
                          - New transmission shift springs.
                          The car won't start or shift out of 0 into 1 or reverse.  Yellow SMG light is on and it just flashes 0.
                          A BMW tech came over and hooked up the computer and there is something not talking to the starter telling it to start.  Should I have him reset the system?  Bleed it?  Bad slave cylinder?  I think the SMG system might have been upside down and leaked some fluid from the reservoir hole.
                          There was water in my SMG circular connector but I cleaned it out and sprayed electrical connector cleaner all over it and blew it out with an air hose.
                          Please help!!!
                            Does the trunk have to be closed to start it?
                              Close the trunk to try lol
                                All these demands!!!!!
                                  It does not start with the trunk closed.
                                  The SMG pump primes just fine when the car is unlocked.
                                    foot on the brake? satanic chant completed?
                                      Did that to no avail.
                                      I feel the smg is preventing the car from starting.
                                      Trying to download DIS_v57 now through a torrent file.
                                        If that torrent doesn't work I have some direct links for you.
                                          A friend let me borrow his computer with the DIS and INPA software. The labtop turns itself into a virtual machine but it won't connect to my car.
                                          The ignition is on but it won't read.
