  4. TehRaydarlover's AWD lover
156 Posts 15 Posters 0 Views 1 Watching
    Thanks for the detailed diff info with pics and part numbers!!
    I may want to pick through your junk parts stash
      Thanks for the great pictures on the dif rebuild. Fyi a wire wheel mostly just melts the undercoating. I used a combination of putty knives and flat screwdrivers to scrape it off. It's not an easy project.
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        No, problem.
        Darn, thanks for the heads up. I'll pick up some putty knives.
          Winter came early eh? Excited to see this build! Great writeup on the dif.
          • TehRaydarloverT
            TehRaydarloverT
            TehRaydarlover
            Finished the diff write up, let me know if I F'd anything up haha.
              Look for thick putty knives with a sharpened edge. I have a stone to sharpen them occasionally and it also knocks off high spots where the sharp edge caught something. You will be surprised how Mich rust is underneath undercoating that looks intact. Mostly around seams. Be careful, mine hasn't been on the road in 2 years, but I'm also married with kids.
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                Finished up another little side project. A rebuildable viscous coupling. First started with cutting a burnt out one open on a lathe.
                The basic idea was to add an extension to the VC barrel for the addition of an o-ring groove and a snap ring groove. After taking a few measurements I mocked everything up in autocad. I rough machined the ring from CA40 420SS and welded it to the VC.
                The cover that was removed from the VC was machined to the max ID of the stator plates. Then the VC extension was finish machined for a 0.001"-0.003" loose fit to the cover. Then the o-ring and snap rings were added.
                And whala, a rebuildable viscous coupling
                  You rock!
                    Wow, miss all this the fisrt time around.
                    Nice work!
                      Crazy good job Ray=) Did you get your secret santa gift by the way?
                        How do you remove that massive internal snap ring? I dont see any holes for a tool to catch onto in the picture
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          Thanks. I did! It sat in front of my door for a few weeks while I was gone for work but luckily my neighbors were decent haha. I'll post a picture tomorrow.
                          • TehRaydarloverT
                            TehRaydarloverT
                            TehRaydarlover
                            There's a big chamfer on the left side (in the picture) that you can pry on with a screw driver to get the end out of the groove. It's actually pretty easy.
                            • TehRaydarloverT
                              TehRaydarloverT
                              TehRaydarlover
                              I also tapped that hole for a 3/8 NPT plug, after removing the pressed ball bearing before I came up with the idea to make it rebuildable. Can also use it to fill the vc with the silicone fluid with the cover on. I made the custom o-ring yesterday so hopefully next week I can pressure test it and put it together for real.
                              post-3378-0-96033600-1450969771thumb.jp
                                Being a magician helps too
                                  What sort of internal pressure does a viscous coupling see? A few psi from heat?
                                  • TehRaydarloverT
                                    TehRaydarloverT
                                    TehRaydarlover
                                    Yeah, shouldn't see much pressure at all, I just want to make sure my o-ring seals well. I had to use a 0.070" o-ring due to space restraints. Shouldn't be a problem but it'd be shitty if the silicone fluid leaked out right at the get go.
                                    • TehRaydarloverT
                                      TehRaydarloverT
                                      TehRaydarlover
                                      So I'm trying to work out my brakes... and could use some advice 😕
                                      Things I'm trying to decide on:
                                      - How far away the caliper should be from the wheel. Leave more room for different wheel options?
                                      - How far can I move the caliper before the rotor hat and adapter bracket offset is enough to cause an undesirable torque during braking?
                                      - Do I even need to be worried about this torque?
                                      The two calipers I have modeled are the Wilwood Forged SL6R (left) and the Wilwood Forged Narrow SL6R (right)
                                      The narrow version is about $75 more a corner, not sure if its worth the price difference, but if the offsets and clearance are an issue the narrow version should be better.
                                      Any help would be greatly appreciated!! 😄
                                        Im assuming the adapter is made from steel or stainless steel and not aluminum, correct?
                                        Does the narrow version of the caliper use different pads than the fatass version?
                                        Are you sticking with 4x100 wheels?
                                        • TehRaydarloverT
                                          TehRaydarloverT
                                          TehRaydarlover
                                          It seems like wilwood and brembo use aluminum, I'm guessing 6160, but I could make it out of 400ss.
                                          Yes, the pads have the same surface area but are .65" thick vs .80". They have the same piston area also.
                                          Wheels are 5X120 using 135i hubs up front and Z4 hubs in the rear 😄
