  4. '88 E30
'88 E30
savebigmoney
    Sweet! I'll have to check out the KBS stuff
      Earl what finish did you use? Or does it only come in satin/gloss etc.
        I used Satan black
          I used Satan black
          Is it a hammered finish? Or smooth depending on the surface? And did you brush it or spray it on?
            You can brush it or spray it on. I brush it on and its a smooth finish depending on surface. It self levels
              Self levels like dave said=) I brushed it on
                Self levels against gravity?
                  Yup
                    Yup
                    Nice. I'll have to give it a try
                      If its earl approved, you know its good :)
                        Hopefully getting out today to take the rest of the brake lines in the rear out as well as the rear sway bar. Bought some face shields so I can clean the entire bottom of the car and then re-undercoat it. The kbs/por-15 will be for the subframes/trailing arms/suspension crap
                          Did you save big money this holiday season?
                            Went to harbor freight actually. Inside track club dude.
                              Scraped, sanded & wire-wheeled my way into being the next face of a class action lawsuit for mesothelioma tonight in the garage. Most of the junk is "prepped" for undercoating spray bombs.
                              So much dust x__x
                              im actually pretty happy with how not shitty the underside of this car is thanks to the previous leaky m50. All the hard mounting points for everything are actually in good shape
                                Got around to cleaning up the front subframe I bought from ray and the rear subframe that's been in my car for forever. (I have reinforcements for both) I will update with photos shortly.
                                It was another awful & dusty day but hopefully it will be worth it.
                                this is how I pushed the power flex bushings out after snaking some wd-40 in between the subframe and bushing
                                  Just like Waldo, a bag of Oil-Dri is always lurking within the picture
                                    Acorns in my fuggin subframe
                                      Ready for reinforcements
                                      Still need to clean up the diff and rear trailing arms.
                                        Anyone have recommendations for coils? I've been leaning towards CAtuned & have spoken with Collin about his... Anything else I should look at? Goals are not stants low, but will want it to be adjustable & stiffer than the crap I have. I figured coils over hr/billies because I could get different rates for the extra weight up front. I'll be running stock sway bars as well
                                          BC Racing, CaTuned, or Fortune 500's
