  4. '88 E30
'88 E30
    Bassboy3313 said:
    Getting it done! Nice work so far
    You shouldnt listen to Brian, KBS rustseal is the way to go over por15 :P
    Is KBS cheaper or something?
      I think so, but not 100% sure. I know you get it next day when you order it. Also can get it in different colors. It's like Franks red hot, I put that shit on everything!
        I used KBS Rust Seal underneath the compact per Daves recommendation=)
          I usually spray everything down with a nice salt water solution to help build immunity in the metals just like you would give a flu shot to a person.  It works wonders!
            Sweet! I'll have to check out the KBS stuff
              Earl what finish did you use? Or does it only come in satin/gloss etc.
                I used Satan black
                  I used Satan black
                  Is it a hammered finish? Or smooth depending on the surface? And did you brush it or spray it on?
                    You can brush it or spray it on. I brush it on and its a smooth finish depending on surface. It self levels
                      Self levels like dave said=) I brushed it on
                        Self levels against gravity?
                          Yup
                            Yup
                            Nice. I'll have to give it a try
                              If its earl approved, you know its good :)
                                Hopefully getting out today to take the rest of the brake lines in the rear out as well as the rear sway bar. Bought some face shields so I can clean the entire bottom of the car and then re-undercoat it. The kbs/por-15 will be for the subframes/trailing arms/suspension crap
                                  Did you save big money this holiday season?
                                    Went to harbor freight actually. Inside track club dude.
                                      Scraped, sanded & wire-wheeled my way into being the next face of a class action lawsuit for mesothelioma tonight in the garage. Most of the junk is "prepped" for undercoating spray bombs.
                                      So much dust x__x
                                      im actually pretty happy with how not shitty the underside of this car is thanks to the previous leaky m50. All the hard mounting points for everything are actually in good shape
                                        Got around to cleaning up the front subframe I bought from ray and the rear subframe that's been in my car for forever. (I have reinforcements for both) I will update with photos shortly.
                                        It was another awful & dusty day but hopefully it will be worth it.
                                        this is how I pushed the power flex bushings out after snaking some wd-40 in between the subframe and bushing
                                          Just like Waldo, a bag of Oil-Dri is always lurking within the picture
