  4. '88 E30
'88 E30
savebigmoney
    I like your breathing exercises!
    I really have not run into anything that doesn't come apart with a reasonable amount of force, the rear subframe bushings are what I would think to be the trickiest part of the suspension to get out, but there are tricks for that as well.
    A whole suspension refresh will feel awesome, I know mine did when I did it. You actually get to drive yours so it will be that much better :)
      This is what I'm excited for. In all honesty when I rode in snaps properly setup m20 car (NA) it felt soooo much better than my car right after I did the s50. Suspension makes such a huge difference, I had to feel it to believe it (no homo)
        What material bushings are you going with?
        Any plans for CAB's?
          Poly (95a) for subframe
          Poly (95a) for diff
          Solid Delrin RTABs
          Solid offset Delrin FCABs
          Engine & trans are already solid Delrin
            That garage looks great!! Times like these are great in the build world. Excited for you!
            FYI, I might be selling my turbo manifold, turbo, and full 3in stainless exhaust next winter...
                I got u bro
                  Hover car
                  Every last bolt I need to remove I've soaked in PB blaster
                  Tires are under it in case harbor freight decides to let me down big time
                  Tools of the hopeless
                  Plan is to drop both front and rear subframes with as much crap intact as possible.
                  I snuck a peek at the RTABs and holy shit. They needed to be replaced about 4 lifetimes ago
                    But babes dont have time for bushings
                    Nice job keeping the garage tidy so far.
                      Parts are all in desperate need of being recycled. I will be cleaning up the rack, getting new tie rods, new boots, etc.
                      Everything came out super easily. Steering rack linkage was the biggest PITA, but came out okay once the subframe was out
                      Parts came in today too!
                        Nice work man!! Are those reinforcement plates and such you got?
                          don't screw up like I did:
                          Make sure you know which end of the steering joint has fine splines and which has coarse splines  aka which end fits on the rack. They are aluminum, the splines are easily wrecked, even if you have the correct ends going together and just dont have them lined up properly before applying some persuasion.  They aren't very easy to find on the used market and when you do, you are usually dealing with dumbasses that want to charge 90% of the price for a new one.
                            Yep!
                              Good to know. I ended up splitting the linkage in half. Neither end wanted to slide off the splines so I said screw it and took it apart in the center.
                                So found out someone replaced the subframe bushings with power flex??? They are soft enough to sink a nail into a bit. But the RTABs are another story.... 60be435c8c79872a49544accea562b97.jpg
                                And there's your problem
                                Good news is the subframe is freely moving with the nuts loosened. So it should come out easy. Just need to disconnect rear lines, drop the exhaust and disconnect the drive shaft and the subframe should fall out. And then get promptly trashed
                                  Did you just re-install the nut on the subframe bolt temporarily or is it actually missing the plate that bolts to the pinch weld?
                                    Reinstalled temporarily so the subframe wouldn't fall on my face. Plates were removed before hand. They had some BS menards hardware that I had to snap out.
                                      You are about to find out that even with all subframe hardware removed the dang thing is stuck to the car by means of black magic.
                                      Having it fall out and hit you in the face would be preferable to some of the profanities you are about to invent while attempting to remove it
                                        ^Johns came out with minimal struggle from what I recall. The one on the compact was cake too=P Just get a large 2x4 and put it between the car and subframe
                                        Then step on it to slowly work it off
                                          You are about to find out that even with all subframe hardware removed the dang thing is stuck to the car by means of black magic.Having it fall out and hit you in the face would be preferable to some of the profanities you are about to invent while attempting to remove it
                                          Mine almost fell out on me - didn't take hardly any effort to remove.
                                          Helped Josh drop his though and it didn't wanna come out. He ended up leaving stands just barely under it and letting the weight hang overnight, then used some force to remove.
