pistonse30
    Sounds like a good table candidate...
      Not much going on lately. Trying to figure out if I should mill down my S52 block to make it perfectly straight, o-ring it and run a thicker MLS gasket. Do the putty thing in the combustion chamber to make sure I'm okay.
      Or..
      Build up one of these m52s that I have been slowly collecting.
      Positives for decking the S52:
      - Use the parts that I have
      - cheapest route
      - more torque
      - I can learn megasquirt on a used motor
      Negatives:
      - there was some detonation so my rods and pistons might be shot (I really don't think they are)
      - thicker head gasket makes for a weaker seal.
      Build M52 positives:
      - take what I've learned from the s52 build and make this one super solid
      - Better head gasket seal
      - can run more boost in future
      Negatives :
      - $$$$$$$ (house projects and getting the M3 back on the road are priority.)
      - Would also like to buy a Blunttech T4 tubular manifold and a big turbo for a lot of boost. $$ (I would sell my turbo, t3 manifold, down pipe and exhaust to compensate)
      - 4 in downpipe and exhaust to be made $$$
      - Did I mention $$$
      Please let me know your thoughts on this. Any input would be greatly appreciated.
        Swap in an L*.........
        Just kidding
        I vote option one with the s52 since it is the cheapest route and you can enjoy the car while doing option 2 if you so please=)
          Just kidding
          I'm leaning this way. Thank you for the input!!
          If I do a LS it would be in a Datsun 240/280z. I have my eye on a mint 280z at a buddies just getting dusty in his barn.
            Now that would be a good candidate for that swap=P I like this car being BMW powered and making whistling noises though haha
              voted s52, you already have fancy internals for it. if the pistons arent melted/cracked id rock em.
                And your rods don't look like this=P
                  Haha
                  • T
                    T
                    tsweers89
                    Usually o-ring and MLS isn't recommended as it's a metal layered gasket. O-ring and factory gasket is what people do it O-ringing. Do you know how much you would be milling down? With low compression pistons MLS usually isn't needed. Unless you think your going to be increasing the compression that much which I wouldn't think the issue would be. Eitherway run e85 and you won't have an issue. If you think your pistons or rods have issues send them out to get analized. They can tell you with doing an xray on them. Better be safe then sorry.
                        I'm thinking MLS because I know they come in a variety of different thicknesses.
                          not that I know anything about building motors but I agree with others, if your S52 internals are good than stick with that since its where all the $$$ is. Like Earl said you can always build another motor later since the E30 is a keeper.
                          • CMartC
                            CMartC
                            CMart
                            Don't LS swap it. I want to line up N/A V8 vs turbo 6.
                            Excursion 7.3
                            E30 LS1
                              My wife got me some "keep the faith" presents for my bday today.
                                Happy 31st! Glad to see the wife supports your cause
                                  Happy Birthday=)
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    Or..
                                    - cheapest route
                                    - more torque
                                    Negatives:
                                    Negatives :
                                    - Did I mention $$$
                                    I interpret this as the eternal plight of every car enthusiast except for Jay Leno.
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                      I finally drained the oil or, should I say water, out of the e30...
                                      After being in the S54 world for a little while it is very refreshing just to be under the e30 and gaze on its simplistic setup.
                                      Making good progress on the S54/M3 stuff.  Getting excited to rip that motor out and get it to the machine shop.  Sitting in the shadows are 2 good m52 heads and a m52 block if anything catastrophic happened with the s52.  I have to put some cheap oil in the s52 to start it and turn the car around so I can use the cherry picker out of the garage door.
                                        Cleaned out the garage a bit. Now I can get at the e30!!
                                        Gotta charge the battery, fill it with oil and back it in the garage so I can pull the motor.
                                          Got the car turned around to pull the motor.
                                          Thinking of selling my s52 stuff and building the s54. Not 100% sure but leaning that way.
