another failed n5x water pump: news at 11
the track went well. I hadn't ever done a BMW CCA event before, and they definitely are a class act. They really treat the event as more of a driving school, with class time even for advanced drivers - obviously for them they are going over more intricate driving techniques.
They also had instructors for everyone in Intermediate and Novice groups. I was impressed that with 40-50 people they were able to get instructors for all of them. It was an impressively large event. Compared to more dedicated DE groups like LAPS, MVP, etc. focused on pure track time where they have like 10-12 instructors and it's a sign-up process where you either take one or don't, and there's a small pool of available people for it.
I learned that I will never drive Novice again. I was passing everyone, and my instructor had to give me a written rec to move into Intermediate. I'm at the point now where I need to be in run groups that are more spread out, don't form congo lines, and just generally have better drivers to surround myself with.
I wish I woulda had the money to do both days.
I have an '07 E92 328i with a little over 105K on it. I've owned it for about 2 years and got fairly complete service records when I bought it. No evidence there was ever a water pump done so that's been at the back of my mind ever since. Did you do the job yourself or take it somewhere? If you took it somewhere, may I ask what they hit you for to do it?
Thanks,
Wally
I had mine crap out on me just last month at 73k. The housing cracked so it worked.. Just leaked. The job isn't tooo bad on a rwd..but the xi is a pain. Ive charged 200 for rwd and 250 for awd. Again a good diyer can do it in a days work. I can swap it in about 2 hours. But ive done a few
Thanks,
Wally
He did the job himself.
yeah IMO it's a DIY job for most mechanically inclined people, at least on n54/n55 cars. The suspension configuration allows you to just unbolt the sway bar bushings and pull it down and rotate out of the way. IMO it is also best to disconnect the fan shroud and lift it a few inches up (no need to fully remove it) - it will give you a TON more space to work with when lining up the E12 for the top water pump bolt. The first time I swapped one of these was on Pat's car and it took 3 hours on the floor. Not a huge job.
I can tell you that my old 135i was under CPO when its water pump failed at 63k so I naturally had BMW replace it and the work sheet read just shy of 1500 for parts and labor, if that helps give you any idea of dealer cost.
The bolts on the pump are easy.but when you have the old aluminum t stat housing those hoses are pure evil to remove lol
dude, those hoses are a fucking rats nest. The first time I did this job I was in disbelief. The 2 supposed "quick release" hoses with the clips required a screwdriver tip to wedge and twist in order to pop them loose, they were ON. A couple of times I thought I had all hoses disconnected only to find another one. That's a couple of times too many
EDIT: Still better than doing the water pump/timing belt on my old V6 acuras. Never thought I'd say that but removing the electric water pump is way better than dealing with a belt driven pump on a J-series honda
Thanks for the tips. Do most guys change the thermostat also? If they aren't really prone to failure, not sure if I will mess with it.
It's a good idea since you have to pull the water pump to do the thermostat. I have read that the pumps are prone to failure when they are removed if they are not stored properly, even for short periods of time. I don't know how true that is but at about $400 a crack for water pumps i'd say it's worth it to do the thermostat as well.
do the thermostat. I was able to get a full kit - thermostat, water pump, and a gallon of coolant for 459 shipped from OEMBimmerParts.com. It shipped from Illinois too so it got here next day
What brand pump did you go with? I got the continental brand with the mann bhear tstat
Mann bhear pigg?
I picked up a water pump and t-stat for $391 shipped from partsgeek.com. I found a $15 off coupon to bring it down to that price. Just in case anyone is interested...
Mann bhear pigg?
Im so serial right now..
