    "Engine tuck"
    https://m.facebook.com/story.php?story_fbid=10155822409920112&id=305901075111&refsrc=http%3A%2F%2Fwww.google.com%2F&_rdr
      Finally scored a foglight switch blank=)
        Ho will you turn your foglights on?
          I don't have foglights anymore=) I've had foglight blanks. My headlights are plenty bright enough and foglights don't seem to last long before getting a rock through them=P
            #e36problems
              but.......fog
                hahahahahaha
                  Finally got around to sandblasting my swaybars and getting them powdercoated. I also did the dipstick tube while I was at it.
                    Tackled a few things this weekend.
                    My passenger side door handle was hanging up on its frame like my drivers side so I removed it and remedied that.
                    I also removed the old Butyl tape from both doors. What a painstaking thing to do...
                    I also removed my brake pedal and added the oilite bronze bushings
                    The modified brake pedal went in after that as well.
                    I went to install the rabbit master cylinder so that I can bend up my front brake lines but I ran into an issue. The rear of the master fouls my firewall when it goes through my booster delete plate. I need to either remove some material from the firewall or source a porsche master that I know fits without any modification. I don't really want to take a dremel to the firewall but I may have to=/
                      Looking good!
                        Putzed on this a bit yesterday
                        Installed the handle trim with new gaskets
                        Installed the rear sway bar. I just aired the car up and installed it. I got my excercise for the day trying to get the brackets situated to bolt them on=P
                          Didn't realize it's been so long without an update. I have been doing little things here and there. Started on extending the wiring harness for the front (headlights, radiator sensors, etc.)
                          I also started installing all of the new rubber trim/mouldings that I ordered.
                          I ended up finding a diff cover without any broken fins and installed that yesterday. I painted it and installed new drain plugs while I was at it. I also got an Ireland Engineering rear diff mount instead of using the Silver Project one in my old cover.
                          I need to get new washers, a speed sensor bracket, and a diff mount bolt because they ended up getting corroded when I prepped my diff with the KBS BLAST for the KBS Rust Seal.
                          You can also see the passenger trailing arm paint was damaged when I installed the subframe. I sanded that down and primed it yesterday. I will be painting it again today.
                          I properly connected the door brakes and installed new boots/covers now too.
                          I also have some goodies that I have been waiting on coming so progress should pick back up=)
                            Looking good man. This thing is going to be better than new when you are done, but with that being said, I hope you drive the piss out of it and dont store it in a plastic bubble the rest of its life.  :lol:
                              No pictures but I putzed around a little yesterday.
                              Removed the drivers window for the last time. I cleaned all of the grime off that would normal sit below the window seal inside of the door. I then recleaned the inside of the door and reinstalled the window. After that I scrubbed the upper window seal with soapy water to remove little bits of plastidip that were still stuck to it. I then installed the lower window seal. I only did the drivers side for now as I am still tracking down a passenger window.
                              Once that was all together I used a battery to directly power the sunroof motor to get it open. I started cleaning up the tracks and surface for the new sunroof seal. I may remove the cassette to make it easier to recover the fabric shuttle and to thoroughly clean all of the sliders and rails. It depends on how clean I can get it tonight.
                              Other than that I have just been ordering little odds and ends that I still needed for the air setup.
                                What did you end up doing with your brake situation? Did you trim the firewall or get a Porsche Master?
                                  Neither. Still debating lol
                                    Snap chat updates ftw
                                      With how much shit is in that sunroof, I may just remove the cassette even though I really don't want to=/
                                      In other news, I've been searching for non ///M lips for a few years and still haven't found any for sale. Im getting more impatient lately and really want one lol. Any from BBS, Zender, Hartge, Racing Dynamics, or AC Schnitzer.
                                        Q tip cleaning
                                          ^I have to have some sort of OCD in a disease form...
