Bay color really doesn't matter to me because I won't have it open for anyone to see unless there is a different motor ever. lol
if only you knew
if only you knew
So young and naive=P lol
your bay is so clean, you tucked the motor!
I don't have foglights anymore=) I've had foglight blanks. My headlights are plenty bright enough and foglights don't seem to last long before getting a rock through them=P
#e36problems
Tackled a few things this weekend.
My passenger side door handle was hanging up on its frame like my drivers side so I removed it and remedied that.
I also removed the old Butyl tape from both doors. What a painstaking thing to do...
I also removed my brake pedal and added the oilite bronze bushings
The modified brake pedal went in after that as well.
I went to install the rabbit master cylinder so that I can bend up my front brake lines but I ran into an issue. The rear of the master fouls my firewall when it goes through my booster delete plate. I need to either remove some material from the firewall or source a porsche master that I know fits without any modification. I don't really want to take a dremel to the firewall but I may have to=/
Looking good!
Didn't realize it's been so long without an update. I have been doing little things here and there. Started on extending the wiring harness for the front (headlights, radiator sensors, etc.)
I also started installing all of the new rubber trim/mouldings that I ordered.
I ended up finding a diff cover without any broken fins and installed that yesterday. I painted it and installed new drain plugs while I was at it. I also got an Ireland Engineering rear diff mount instead of using the Silver Project one in my old cover.
I need to get new washers, a speed sensor bracket, and a diff mount bolt because they ended up getting corroded when I prepped my diff with the KBS BLAST for the KBS Rust Seal.
You can also see the passenger trailing arm paint was damaged when I installed the subframe. I sanded that down and primed it yesterday. I will be painting it again today.
I properly connected the door brakes and installed new boots/covers now too.
I also have some goodies that I have been waiting on coming so progress should pick back up=)
No pictures but I putzed around a little yesterday.
Removed the drivers window for the last time. I cleaned all of the grime off that would normal sit below the window seal inside of the door. I then recleaned the inside of the door and reinstalled the window. After that I scrubbed the upper window seal with soapy water to remove little bits of plastidip that were still stuck to it. I then installed the lower window seal. I only did the drivers side for now as I am still tracking down a passenger window.
Once that was all together I used a battery to directly power the sunroof motor to get it open. I started cleaning up the tracks and surface for the new sunroof seal. I may remove the cassette to make it easier to recover the fabric shuttle and to thoroughly clean all of the sliders and rails. It depends on how clean I can get it tonight.
Other than that I have just been ordering little odds and ends that I still needed for the air setup.
