Looking good!
Didn't realize it's been so long without an update. I have been doing little things here and there. Started on extending the wiring harness for the front (headlights, radiator sensors, etc.)
I also started installing all of the new rubber trim/mouldings that I ordered.
I ended up finding a diff cover without any broken fins and installed that yesterday. I painted it and installed new drain plugs while I was at it. I also got an Ireland Engineering rear diff mount instead of using the Silver Project one in my old cover.
I need to get new washers, a speed sensor bracket, and a diff mount bolt because they ended up getting corroded when I prepped my diff with the KBS BLAST for the KBS Rust Seal.
You can also see the passenger trailing arm paint was damaged when I installed the subframe. I sanded that down and primed it yesterday. I will be painting it again today.
I properly connected the door brakes and installed new boots/covers now too.
I also have some goodies that I have been waiting on coming so progress should pick back up=)
No pictures but I putzed around a little yesterday.
Removed the drivers window for the last time. I cleaned all of the grime off that would normal sit below the window seal inside of the door. I then recleaned the inside of the door and reinstalled the window. After that I scrubbed the upper window seal with soapy water to remove little bits of plastidip that were still stuck to it. I then installed the lower window seal. I only did the drivers side for now as I am still tracking down a passenger window.
Once that was all together I used a battery to directly power the sunroof motor to get it open. I started cleaning up the tracks and surface for the new sunroof seal. I may remove the cassette to make it easier to recover the fabric shuttle and to thoroughly clean all of the sliders and rails. It depends on how clean I can get it tonight.
Other than that I have just been ordering little odds and ends that I still needed for the air setup.
With how much shit is in that sunroof, I may just remove the cassette even though I really don't want to=/
In other news, I've been searching for non ///M lips for a few years and still haven't found any for sale. Im getting more impatient lately and really want one lol. Any from BBS, Zender, Hartge, Racing Dynamics, or AC Schnitzer.
Q tip cleaning
I was holding that off until I get the engine in and the harness snuck through the firewall to meet the fusebox. I should also wire up all of my air ride components so I can easily run the wire/cables.
Well, what are you waiting for?
Do it earl
