  4. '88 E30
'88 E30
savebigmoney
1.1k Posts 36 Posters 12.0k Views 2 Watching
    Bought a tune from sssquid and learned a lot about DMEs. He's very helpful and his price was $175 vs TRM @$250
    • andyhundleyA
      andyhundleyA
      andyhundley
      This car needs a Dinan supercharger. I know a guy if your interested. :D
        Just bought an NA tune
          Color me intrigued
            It runs! Open headers @11pm is chub-tastic
              Burnout video or it didn't happen.
                Hahah. I don't have a driveshaft
                      Driveshaft. Flex disc and csb all ordered.
                      Still need to wire up the fan relay, bleed new slave cyl. Finish bleeding coolant system.
                      Then done (lol)
                      • CMartC
                        CMartC
                        CMart
                        Link to that radiator?
                        Excursion 7.3
                        E30 LS1
                          http://catuned.com/mishimoto-bmw-e30e36-performance-aluminum-radiator
                          I got mine from catuned when they were on sale for $215
                          Otherwise blunt tech has them as well(might be faster shipping)
                          Regular they are $255
                          Might be able to find them for even cheaper on the interwebs
                          • CMartC
                            CMartC
                            CMart
                            Nice I thought mine was going to be that size.
                            I guess Ill just wait and see if it can handle the heat.
                            Excursion 7.3
                            E30 LS1
                              Finished up the fan wiring last night.
                              Toggle switch with red LED when fan is on
                              Rats nest with 2, 20amp fuses (switch is a 25amp) I popped one of these on accident while testing the fan, so I'm glad I have them.
                              Wires routed with some adhesive clips. Relay kinda tucked in the fender so it is easy to get to.
                              Made some labels because I wanted to use all black 14g wire so it didn't look like streamers under the hood
                              Aaaaaaaand. Mounted. Had to redo the two leads on the fan, I messed up power/ground. So my pusher acted as a puller--all good now!
                              Also ordered some new carpet for this thing last night. I got sick of looking at shitty floors.
                              Any one have any experience with dyeing the parcel shelf?? I want mine to be black. Is it worth the hassle? Or just easier to find a black one?
                                where did you get heat shrink labeler?! thats awesome.
                                  They are like regular label maker cartridges. But it prints it on shrink tube. They worked pretty well
                                    Went out an bought some duplicolor vinyl and carpet paint I'm an aerosol can. Worked awesome and was easy to use. I now have a black parcel shelf.
                                    Valence is also mounted-ish.
                                    Driveline stuff gets here today (Thursday). the car might move under its own power by the weekend...
                                      Only thing left is bleed slave. Split driveshaft, install CSB. Install driveshaft. Do burnouts
                                        I drove it last night at about 2am
                                        Car makes top end noise. Like bad m20 top end noise (couldn't hear it when I started it with open headers)
                                        I'm probably going to be buying a daily driver within the next month or so. The e30 will get to sit. Kinda sucks getting literally everything back together only to find out the motor sounds like it has marbles in it.
                                        Only thing I can think of is vanos, timing chain guides, lifter tick
                                        Now might be a good time to send the head out...
                                          My M42 had serious lifter tick the first time I started it up, even after idling for 5 or 10 minutes. I was really depressed that something was fucked.Took it up and down the block a few times and it was 95% gone. Seems like the lifters need a couple good beat-run to get pumped up. You may have the same problem...
