  4. '88 E30
'88 E30
    Pretty much everything is hooked up now.
    Still need driveline stuff and I'll be ordering a sssquid tune shortly to get rid of the EWS and get a basic tune for now. Still have to attach new stainless clutch line and bleed clutch. Need to attach radiator/hoses, fill and bleed. Need to Figure out a way to mount to bumper for now as well
      Bumpers are overrated.
      Sent from my potato phone using Tapatalk 2
        Scratch the tune comment. Still emailing back and forth with squid and TRM.
          Bought a tune from sssquid and learned a lot about DMEs. He's very helpful and his price was $175 vs TRM @$250
          • andyhundleyA
            andyhundleyA
            andyhundley
            This car needs a Dinan supercharger. I know a guy if your interested. :D
              Just bought an NA tune
                Color me intrigued
                  It runs! Open headers @11pm is chub-tastic
                    Burnout video or it didn't happen.
                      Hahah. I don't have a driveshaft
                            Driveshaft. Flex disc and csb all ordered.
                            Still need to wire up the fan relay, bleed new slave cyl. Finish bleeding coolant system.
                            Then done (lol)
                            • CMartC
                              CMartC
                              CMart
                              Link to that radiator?
                              Excursion 7.3
                              E30 LS1
                                http://catuned.com/mishimoto-bmw-e30e36-performance-aluminum-radiator
                                I got mine from catuned when they were on sale for $215
                                Otherwise blunt tech has them as well(might be faster shipping)
                                Regular they are $255
                                Might be able to find them for even cheaper on the interwebs
                                • CMartC
                                  CMartC
                                  CMart
                                  Nice I thought mine was going to be that size.
                                  I guess Ill just wait and see if it can handle the heat.
                                  Excursion 7.3
                                  E30 LS1
                                    Finished up the fan wiring last night.
                                    Toggle switch with red LED when fan is on
                                    Rats nest with 2, 20amp fuses (switch is a 25amp) I popped one of these on accident while testing the fan, so I'm glad I have them.
                                    Wires routed with some adhesive clips. Relay kinda tucked in the fender so it is easy to get to.
                                    Made some labels because I wanted to use all black 14g wire so it didn't look like streamers under the hood
                                    Aaaaaaaand. Mounted. Had to redo the two leads on the fan, I messed up power/ground. So my pusher acted as a puller--all good now!
                                    Also ordered some new carpet for this thing last night. I got sick of looking at shitty floors.
                                    Any one have any experience with dyeing the parcel shelf?? I want mine to be black. Is it worth the hassle? Or just easier to find a black one?
                                      where did you get heat shrink labeler?! thats awesome.
                                        They are like regular label maker cartridges. But it prints it on shrink tube. They worked pretty well
                                          Went out an bought some duplicolor vinyl and carpet paint I'm an aerosol can. Worked awesome and was easy to use. I now have a black parcel shelf.
                                          Valence is also mounted-ish.
                                          Driveline stuff gets here today (Thursday). the car might move under its own power by the weekend...
