813 Posts 31 Posters 0 Views 1 Watching
    My O'reilly's is out of it...
      I bought everything the O'Reillys on hwy 100 & Greenfield had. Hopefully that wasn't the one you went to, lol. The O'Reillys by my house in bayview doesnt even sell 20w50 which I found weird.
        I just called the O'Reillys in West Bend and they don't have any. Pooey=/
          I can probably grab some more for people if they want to pick it up from my house in bayview or meet somewhere close. Just a thought.
            Got 5 quarts of engine oil in (one small leak I need to fix), coolant filled up and trans filled with redline MTL. Figured I should see what the fuel looks like from sitting for such a long time... Removed the hose connecting the 2 tanks to drain and this is what came out :blink:
            Looks like I'll be dropping the tanks, cleaning them out and sealing them with kbs fuel tank sealer. First start up has officially been postponed. Might even remove the fuel accumulator and replace the fuel filter and pump with e30 units.
              How long was the fuel sitting for?
                I recently had a tank cleaned at Mike's radiator in Waukesha. Did a great job and it was only $45. I think he gets $100-150 for cleaning and sealing.
                  Well over a year and a half I'd say. I'm probably just more paranoid about running shitty fuel and tank with the fresh engine I spent so much time and money on. Should probably be done anyways since its a 30+ year old fuel tank.
                  Good to know. Thanks!
                    Tanks are out. Way more rust on the tops of the tanks than the bottoms. I'll take them to Mike's radiator tomorrow (if they're open) and see what he says.
                      Remember to tell Mike "tanks" when you drop them off.
                      (Ba-dum pshh!)
                        Got more rusty metal out of the driver side floor pans.
                        Accelerator pedal broke at the floor mounting point which is fine since it was already broken at the top anyways. Ordered a new one from fcpeuro.
                        I cleaned the remaining metal, applied rust killer and will be painting it with kbs rustseal tomorrow or Sunday.
                        On a side note, the radiator shops I was going to take the fuel tanks to for price quotes were both closed today. Looks like I'll have to wait till next week sometime.
                          The new go pedal
                            Boring. :D
                              Theres a toe cage and everything!
                                Got the fuel tanks in, fuel lines replaced, battery cable ran to trunk and connected and filled with fresh gas. Turned the key for its first start, saw smoke from the engine compartment, turned key off and saw this ...
                                No idea why that wire fried. :unsure:
                                  Oh no.....the curse continues
                                    Brian (snap) and I brained stormed for a bit and came to a conclusion that the relay I have in that spot may not be the correct relay. So, I will be getting a new relay socket this week to replace the one I have with burnt wire and also a "correct" relay. Hopefully that solves it and I can attempt to start then engine for first time.
                                      Yikes. Definitely a circuit that's not fused... I believe E30s have a "fusible link" somewhere that's supposed to stop things starting on fire like that. Maybe something guys like you and me should look into...
                                        I have been swamped with work and decal orders, so no time to work on this thing. Hopefully this weekend will be a different story. Brian and I are extremely certain that the wrong relay was used which had the high current positive and ground reversed compared to the correct e30 (white) relay. I have a relay coming in the mail soon and just need to make a new wire in place of the one that burnt. Crossing fingers that is it.
                                          replaced the burnt wire and got the correct main relay in. turned key on and no smoke this time, good sign. went to start it, just clicked, bad sign. Brian came over to do some electrical ecu tests and  all checked out except power to the fuel pump. hhmmm. fuel pump ran the first time i turned the key and relay wire smoked, but nothimg since. so now 2 issues.
                                          i got the battery charged up at oreilly so i could rule that out. still just clicked. so i got a remote trigger starter, connected it to diagnostic port and she cranked away perfectly. heaven to my ears. now i know my ignition switch is bad and will most likely move to a pish button type ignition setup with hidden kill switch.
                                          as for fuel pump not working, still a mystery for now. any suggestions?
