    Bassboy3313 said:
    O'reilly's currently has Valvoline Max Life 20w50 synthetic blend for $1.07 a quart! :o Originally over $6 a quart. The guy at the O'reilly I went to thanked me for taking every last bottle they had, lol.
    Is this every O'Reillys?
      Seems like it since its on the website
      http://www.oreillyauto.com/site/c/detail/VAL1/MAXLIFE2050/N1879.oap?ck=Search_20w50_N1879_-1_3463&keyword=20w50&pt=N1879&ppt=C0368
        Heading there now
          I am going to get some after work as well!
            WOW thanks for the tip! this ETA eats oil like its going out of style.
              My O'reilly's is out of it...
                I bought everything the O'Reillys on hwy 100 & Greenfield had. Hopefully that wasn't the one you went to, lol. The O'Reillys by my house in bayview doesnt even sell 20w50 which I found weird.
                  I just called the O'Reillys in West Bend and they don't have any. Pooey=/
                    I can probably grab some more for people if they want to pick it up from my house in bayview or meet somewhere close. Just a thought.
                      Got 5 quarts of engine oil in (one small leak I need to fix), coolant filled up and trans filled with redline MTL. Figured I should see what the fuel looks like from sitting for such a long time... Removed the hose connecting the 2 tanks to drain and this is what came out :blink:
                      Looks like I'll be dropping the tanks, cleaning them out and sealing them with kbs fuel tank sealer. First start up has officially been postponed. Might even remove the fuel accumulator and replace the fuel filter and pump with e30 units.
                        How long was the fuel sitting for?
                          I recently had a tank cleaned at Mike's radiator in Waukesha. Did a great job and it was only $45. I think he gets $100-150 for cleaning and sealing.
                            Well over a year and a half I'd say. I'm probably just more paranoid about running shitty fuel and tank with the fresh engine I spent so much time and money on. Should probably be done anyways since its a 30+ year old fuel tank.
                            Good to know. Thanks!
                              Tanks are out. Way more rust on the tops of the tanks than the bottoms. I'll take them to Mike's radiator tomorrow (if they're open) and see what he says.
                                Remember to tell Mike "tanks" when you drop them off.
                                (Ba-dum pshh!)
                                  Got more rusty metal out of the driver side floor pans.
                                  Accelerator pedal broke at the floor mounting point which is fine since it was already broken at the top anyways. Ordered a new one from fcpeuro.
                                  I cleaned the remaining metal, applied rust killer and will be painting it with kbs rustseal tomorrow or Sunday.
                                  On a side note, the radiator shops I was going to take the fuel tanks to for price quotes were both closed today. Looks like I'll have to wait till next week sometime.
                                    The new go pedal
                                      Boring. :D
                                        Theres a toe cage and everything!
                                          Got the fuel tanks in, fuel lines replaced, battery cable ran to trunk and connected and filled with fresh gas. Turned the key for its first start, saw smoke from the engine compartment, turned key off and saw this ...
                                          No idea why that wire fried. :unsure:
