  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Were you driving this on 41/45 south bound at 4:15ish yesterday near Capital?
      Maybe. I was all over Milwaukee yesterday I can't remember my time frames.
      Stock tune to come today.
      I also had a nightmare that the M3's head gasket blew. I have to get these cars fixed!! Haha
        The stock tune made a huge difference being that the car doesn't sound like a old ford pickup with a bad exhaust manifold gasket. The light still came on. After talking with Frank Smith from tuning tech we think the 2 cam and crank sensors should be replaced. I will order those tomorrow. I'm thinking that is why the car doesn't start on the first try. I also have replaced almost everything else that would throw the o2 sensor codes.
          Break My Wallet
          So the car runs better on the stock tune then?
            Break My Wallet So the car runs better on the stock tune then?
            I'm thinking the file that was on the computer that he made the tune off of was of the car running poorly.
            I'm getting the 2 cam sensors and crank sensor tomorrow to see if that fixes the problem.
              Next to do after I replace the sensors.  The music gets you in the wrenching mood.
              https://www.youtube.com/watch?v=9SkT2j3jsU0
                Ordered cam and crank sensors. Should be in tomorrow afternoon.
                  For reference :
                  http://www.e46fanatics.com/forum/showthread.php?t=862891
                  • T
                    T
                    tsweers89
                    So your pulling the intake manifold. Unless someone replaced the clamps that hold it on each throttle body to normal hose clamps your going to need the special pliers/tool to take them off and put them back on.
                      Didn't take pics but I replaced the intake, exhaust and crank sensors.
                      Cleaner the throttle bodies and checked if they were adjusted properly.
                      Cleaned the inside of the intake manifold.
                      Cleaned the ICV.
                      Properly connected the SMG Reservoir line and topped it off with fluid. It was leaking.
                      Replaced what I think was the fuel relay.
                        Took it for a 66 mile drive late last night. No engine light after I cleared the adaptations. However, I'm still not 100% positive it's fixed.
                          Is the performance what it should be?
                            It does feel good. I'm about to get some coffee and go for a long drive.
                              Too lean codes popped up banks 1 & 2.
                              Checked for vacuum pressure ant it looks perfect.
                              Going to clean the MAF and re-seal it in the housing.
                                Could this be the problem?? It is really dry and cracked
                                  I'd think that if that gas cap were the issue, you'd be throwing an evap code.
                                  • T
                                    T
                                    tsweers89
                                    Smoke test it for leaks in the intake track or such. Start there. Also gas cap will not cause those faults. Would be evap faults. I'm lost as to why you continue to throw parts at it and not have someone with the know how diagnose it properly. Just look at all the parts you installed that wernt needed.
                                      Timmy, it has been tested for vacuum leaks. I replaced the pre-cat O2 sensors w/OEM parts. I have 137K on the motor. Why not replace the cam sensors? New MAF due to the too lean codes.
                                      What is the problem if you're so knowledgeable? Where would you start?
                                      • T
                                        T
                                        tsweers89
                                        I'd personally drop it off at Matts shop down the street from Concours and have him diagnose this issue. Without being there I cant really tell you what to do. Usually a bad maf will cause a rich mixture though not lean. What are the multiplicative and additive fuel adaptations values? Have you drove and checked fuel pressure? What about injectors starting to clog? Bad ecu? Exhaust leaks? Etc. All things that can cause lean mixtures. Without the car in front of me I can't diagnosis obviously. You sound like you don't know were to go as you are taking everyone else's advice and throwing parts at the issue. Also sure you have 137k on the motor...so what? Why don't you rebuild the motor then as "preventive maintenance" i mean were does it end? You know people at concours to. Why can't yout have them take a peek?
                                          There is value in learning about your car and increasing your diagnostic ability and engine knowledge by troubleshooting and working out problems yourself. You spend extra time and money doing so but valuable experience is gained.
                                          Another reason to go at it yourself is the lack of trust and credibility a lot of shops have.
                                          I use shops pretty much just for tire mounting and alignment since the required tools arent available for my personal use. Even then it gets difficult to deal with the incompetency of shops.
                                          The last two experiences I had with shops were
                                          -they didnt have the "special bmw tool" to do an alignment on my E30 which only has adjustable toe
                                          -On a Nissan Versa they quoted an extra $39 for tire mounting to re-program the TPMS sensors "so the car will know which corner has which sensor". Re-install the wheel from the same corner you removed it from then???? "Nope it just doesnt work like that"
