Do not use the axle nuts that come with those half shafts, buy new ones and lock plates.
It all looks so shiny!
Do not use the axle nuts that come with those half shafts, buy new ones and lock plates. It all looks so shiny!
Wait what? I have new axle nuts for the half shalfs and I have new locking plates as well. Why should I not use them?
Are they OEM Halfshafts?
If so no worries. -
If so no worries.
They are not, but I got them on Worldpac, so they are high quality. Have you had an Axle nut fail before?
I had issues with the supplied hardware for an aftermarket or reman axle once, the axle also lasted 150 miles lol.
I have not had good luck with aftermarket axles, so I hope these work fine for you. -
Ahh, yeah I have had issues with axles before on other cars. These look to be great quality, I am not too worried. I will let you know if a few thousand miles how they hold up.
I never shared photos of pressing the new bearings in.. So let me step back a sec...
Heres the tool of choice...
using some random old bearing races and chunks of aluminum, I was able to press out the hubs, then the bearings.
One thing I learned from this whole ordeal was that it sucks if you accidentally bend the shields. They hold the e-brake shoes a specific distance from the swing arms. Once they are tweaked, it takes a lot of manipulating and patience to get them just right again so that everything lines up. Something that should have taken me 20 minutes now took me over 2 hours.
At the end of the day, everything went together well and I was happy.
Before
After
Looks awesome, its all about having the right tools. Sent from my potato phone
Thanks, and it sure does help having the right tools for the job!
So, I drove the car for the first time last night, and I drove it to work today. Unfortunately from sitting apart with no fluid in the master cylinder for so long, it failed. I have a tilton that I bought from Jason89i but I dont want to install it just yet because I need to figure out new lines and mounting. So I will be installing a new master and possibly a booster if that is bad too(I hope not). Other than that the car drove rather good and feels a lot more solid and responsive now that everything is new. I also was able to lower it more since the bushings are not all sloppy and flexy.
So my new master cylinder should be showing up today as I paid for express shipping. My new issue is the LSD 4.10 diff I just installed. At speeds is whines or whurrs loudly so I assume a bearing is bad. Besides that, under load, or initial power engagement, there is a clunk coming from the rear end. at first I was assuming it was the new axles, but now under further inspection, I am fairly certain it is worn gears or clutch discs inside the Diff. It seemed smooth outside of the car, but that's no comparison to actually putting it under load.I also just swapped new royal purple fluid into it praying it would make a difference. I need a new LSD while I rebuild this one. Does anyone have a good LSD 3.73 or 4.10 they are willing to part with?
I can give you my 4.10 LSD and my 3.73 OPEN in trade....
I don't think you want a small case though...
I found A viscous LSD from a guy in Chicago via help from Snap! Thanks for the offer though.
Not a fan on an e30
Gross.
I agree. I was thinking they might look good on my civic...
Also in other news I ordered and installed a new master cylinder from a 750i to upgrade from a 22.3mm master to a 25mm. It helped a lot and my brakes feel more solid, But like I feared, when the master went bad, so did my booster, and I have about an inch of brake pedal that does nothing. So I managed to pick up a booster from Cmart this weekend and will be installing it this week.
So I haven't updated much in awhile. I was able to get my car drivable and I made the 1800 mile trip to Helen, Ga. for SoWo 2015. My car ran great the whole time minus the traffic jams and slight overheating because clutch fan. I almost made it back unscathed but shitty roads got the best of me, even though I made it just fine through hours of carving mountain roads including the tail of the dragon. Some where along the flat borings of Kentucky, I cracked a barrel on one of my HRE's. So lucky enough, one of my good friends let me burrow a set of BBS Rs's he had sitting around.
Oh and BTW they are for sale
Are those Andy's wheels?
