  4. '88 E30
'88 E30
savebigmoney
    and you can be cool and say it is ///M swapped...
      I'll tell people it's 325e swapped
        So in my efforts to swop. I also want to clean up as much stuff within the bay as possible.
        I am torn on running heat or not I will be passing the TB.
        Still on the fence with PS too.
        The evap/charcoal canister can thing I would also like to ditch. Assuming this would be as simple as venting to atmosphere? There is also a connector that goes from the TB to the top of this (purge valve?) assuming that would still need to be plugged into the harness otherwise it will throw a cel?
        The line with the red tape is the line coming from the gas tank. Other line with harness plug goes to TB
          Why vent your expensive fuel vapors to atmosphere?
          Sent from my potato phone
            So I can get rid of a crusty piece of shit that's 27 years old.
            I wonder how functional it is in its current state.
            But mainly so I have one less thing to put back into the car
              It's clogged right now lol. Take it out Haha
                Driveshaft is off
                Trans mount is off
                Only thing holding engine in right now is slave cylinder/line
                Engine mounts. Shift selector.
                And motivation
                  So I can get ride of a crusty piece of shit that's 27 years old.
                    Use a plastic e36 one, or a universal one. Weighs nothing and keeps your car from smelling like gas all of the time.
                    Good work on the swop, this should be awesome.
                    Id welcome the smell of gas.
                    This thing smells like oil/coolant now
                      In all seriousness though, I may replace it and try and hide it somewhere. The one that was on there now is zip tied to the brake lines
                        the smell really isn't anything noticeable in my experience. Mine has been removed/vented to atmosphere since I got the car and never have i smelled gas to the point of getting annoyed. But then again, I know, engines/cars are not all created equal.
                          Driveshaft is off
                          Transmission mount off
                          Exhaust is off
                          Only things left are the slave cylinder & engine mounts
                          Hoping I'll be able to pull motor with headers attached...
                            a2c27819afd5b6801ba3e482564ec1165b11d2bf
                              Removable core support was the best decision in my life (a close second was Mac sauce on a mcchicken. -no lettuce because I'm not a damn rabbit)
                              This is one greasy bitch.
                              Good news is my car protected itself from rusting any worse than it already was by neatly spreading oil everywhere.
                              Anyhow. This will chill on some tires until it finds a new home.
                              defae9a0b7bd7573ab1ea3287224a248.jpg505569baa9d34f36ebf88b58266fd0a6.jpg222949be9967b6e2ef6077c72b4859a1.jpg
                              Super glad I picked up bottlecaps from Drleadballs on the cheap.
                              The hoist was too tall to fit under the rack.
                              I didn't want to put the car on jackstands.
                              So substitute bottlecaps (a close third behind Mac sauce on a mcchicken, maybe even a tie?)
                              That's about it for now. Gonna clean the bejesus out of everything. And then maybe get around to ordering parts for the s50.
                                Trans is clean enough for me.
                                I do give earl props for the tooth brush. I used a wire brush for 14 seconds and gave up. Sprayed it with gunk and pressure washed it instead. 70d8a043087b149a309696fbf6392e51.jpg
                                Then rolled the car outside, gunked it & pressure washed it. Rolled it inside, cleaned some more and then temporarily hit it with flat black (I believe the PO had satin/semi gloss) I may try to go back to that. Not sure
                                It's no gunmetalgray bay, but I'm okay with it :P
                                  Still have yet to order parts
                                    What was your decision on the charcoal canister?
                                    I got rid of mine last year including the hardline that ran to the back, had it wrong the tank pressurized which was funny. I am now venting to atmosphere and using a garden tractor style fuel filter to keep things clean.
                                      I'm just going to vent to atmosphere and toss a filter on the line
                                        Yep, that's how I ended up.
                                          Going to hold myself to actually ordering parts tonight so I can get this thing back together
