  4. '88 E30
'88 E30
savebigmoney
    the smell really isn't anything noticeable in my experience. Mine has been removed/vented to atmosphere since I got the car and never have i smelled gas to the point of getting annoyed. But then again, I know, engines/cars are not all created equal.
      Driveshaft is off
      Transmission mount off
      Exhaust is off
      Only things left are the slave cylinder & engine mounts
      Hoping I'll be able to pull motor with headers attached...
        a2c27819afd5b6801ba3e482564ec1165b11d2bf
          Removable core support was the best decision in my life (a close second was Mac sauce on a mcchicken. -no lettuce because I'm not a damn rabbit)
          This is one greasy bitch.
          Good news is my car protected itself from rusting any worse than it already was by neatly spreading oil everywhere.
          Anyhow. This will chill on some tires until it finds a new home.
          defae9a0b7bd7573ab1ea3287224a248.jpg505569baa9d34f36ebf88b58266fd0a6.jpg222949be9967b6e2ef6077c72b4859a1.jpg
          Super glad I picked up bottlecaps from Drleadballs on the cheap.
          The hoist was too tall to fit under the rack.
          I didn't want to put the car on jackstands.
          So substitute bottlecaps (a close third behind Mac sauce on a mcchicken, maybe even a tie?)
          That's about it for now. Gonna clean the bejesus out of everything. And then maybe get around to ordering parts for the s50.
            Trans is clean enough for me.
            I do give earl props for the tooth brush. I used a wire brush for 14 seconds and gave up. Sprayed it with gunk and pressure washed it instead. 70d8a043087b149a309696fbf6392e51.jpg
            Then rolled the car outside, gunked it & pressure washed it. Rolled it inside, cleaned some more and then temporarily hit it with flat black (I believe the PO had satin/semi gloss) I may try to go back to that. Not sure
            It's no gunmetalgray bay, but I'm okay with it :P
              Still have yet to order parts
                What was your decision on the charcoal canister?
                I got rid of mine last year including the hardline that ran to the back, had it wrong the tank pressurized which was funny. I am now venting to atmosphere and using a garden tractor style fuel filter to keep things clean.
                  I'm just going to vent to atmosphere and toss a filter on the line
                    Yep, that's how I ended up.
                      Going to hold myself to actually ordering parts tonight so I can get this thing back together
                        Why isn't this done yet? Ay ay ay!!
                        • andyhundleyA
                          andyhundleyA
                          andyhundley
                          Are you gonna make it to the E30 Picnic?
                            Is that a Garagistic bar?
                              Ireland engineering
                                Because I suck at buying things
                                Nope. Going to automotion with some friends
                                  Parts should be getting here mid to late next week.
                                  I'll be able to get the s50 sealed up and ready to go.
                                  Still have to order a radiator/hoses, engine mounts, Trans mounts, O2 sensor and some random other crap for the car.
                                  Right now the focus is on getting the motor sealed up & ready
                                    This stuff was a pain in the ass
                                    After the silicone spray to seal&make color last
                                    Exhaust Hardware/gaskets came today as well. New studs to mount these and then the rest of the parts show up Thursday/Friday hopefully
                                      Does header wrap still cause manifolds to corrode and crack?
                                        Did you get new lock nutz?
                                          Under the "Fair Oxidation Treaty of 2013" wraps and coatings applied to tubular internal combustion engine components are now exempt from defects caused by corrosion.
