  4. '88 E30
'88 E30
savebigmoney
    If you are driving through wausau my engine stand is at my parents house, you are welcome to use it.
    Sent from my potato phone
      The s50 is currently on the stand when the m50 comes out I'm swapping the e34 pan and other stuff off of it. Then dress the s50, put m50 on tires, then put s50 in. M50 going to a buddy who is gonna give me driveshaft/clutch and some help over a weekend
      At least that's the plan
      I have yet to order any parts haha
        Harbor freight strikes again!!
        No hoists in stock
        But I got a super cool rain check
          The rain delay!
            DrLeadFoot said:
            The rain delay!
            H3W4IT5
              https://trust.dot.state.wi.us/ppup/searchPlate.do
              It's available...
                May I ask why you went m50-s50? No plans of other mods in the future?
                  M50 + G250 is pretty high miles (240xxx) or so
                  S50 + ZF + DME + harness was cheaper than rebuilding an M50, and has almost 80xxx less miles.
                  I'll slowly add other things to the car as well. Suspension stuffs and such.
                  It's pretty much plug and play for some extra hp/torque and still cheaper than pouring money into a leaky m50
                  And it's something to keep me busy
                    and you can be cool and say it is ///M swapped...
                      I'll tell people it's 325e swapped
                        So in my efforts to swop. I also want to clean up as much stuff within the bay as possible.
                        I am torn on running heat or not I will be passing the TB.
                        Still on the fence with PS too.
                        The evap/charcoal canister can thing I would also like to ditch. Assuming this would be as simple as venting to atmosphere? There is also a connector that goes from the TB to the top of this (purge valve?) assuming that would still need to be plugged into the harness otherwise it will throw a cel?
                        The line with the red tape is the line coming from the gas tank. Other line with harness plug goes to TB
                          Why vent your expensive fuel vapors to atmosphere?
                            So I can get rid of a crusty piece of shit that's 27 years old.
                            I wonder how functional it is in its current state.
                            But mainly so I have one less thing to put back into the car
                              It's clogged right now lol. Take it out Haha
                                Driveshaft is off
                                Trans mount is off
                                Only thing holding engine in right now is slave cylinder/line
                                Engine mounts. Shift selector.
                                And motivation
                                  So I can get ride of a crusty piece of shit that's 27 years old.
                                    Use a plastic e36 one, or a universal one. Weighs nothing and keeps your car from smelling like gas all of the time.
                                    Good work on the swop, this should be awesome.
                                    Id welcome the smell of gas.
                                    This thing smells like oil/coolant now
                                      In all seriousness though, I may replace it and try and hide it somewhere. The one that was on there now is zip tied to the brake lines
                                        the smell really isn't anything noticeable in my experience. Mine has been removed/vented to atmosphere since I got the car and never have i smelled gas to the point of getting annoyed. But then again, I know, engines/cars are not all created equal.
                                          Driveshaft is off
                                          Transmission mount off
                                          Exhaust is off
                                          Only things left are the slave cylinder & engine mounts
                                          Hoping I'll be able to pull motor with headers attached...
