You missed the engine bay pic of that second bmw!!!
But hey this is exciting
Also. Is that an r154? DId you give up on the adapter? I'm very much so thinking my next swap will be 4g63 into an e30 for a daily.
Ahhhh, I was waiting for someone to ask what trans that was..
and no, I did not give up on the adapter, but the price was right so I had to! BTW you didn't miss much, that E30 was just a stock M20. -
Are you going to at least tell me what trans? Ha. Sent from my iPhone using Tapatalk
Only if you can guess what it is. You were close though lol.
What sideskirts are you rockin'?
Genuine Rieger side skirts sir. I plan on getting the Reiger Infinity front lip to match soon too, but I just want to get the moving bits all squared away first.
More updates. Since I had the back seat out to remove the subframe, I took my seat to a local friend of a friend that does interior upholstery to have the top of the seat restitched. The plastic rear window amplifies the sun and bakes the top of almost all the vert rear seats. My seat was extremely dry and fragile when I got the car, and after the first year of owning it and packing people into the back, the stitching gave away. I have since added lots and lots of leather replenishing chemicals and the leather has bounced back quite well, so I finally got it fixed. I unfortunately did not take any before pictures of the seat, but here is what it looks like now that I got it back(I have since cleaned and replenished the leather).
Focusing back on the suspension, I go the new control arms installed, along with the new sway bar links and brackets, the calipers I rebuilt, and I installed the new lines. it all came together very nice and I am getting excited to drive this thing more and more each day.
New sway bar links
Old brake line
New VS. Old brake lines side by side
Everything installed and back together minus the wheels
I also rebuilt the calipers, but due to having brake fluid all over, I didn't take any pictures.
Looks great! Gonna drive like a new car
Thanks! I am super excited!
Lookin perrrrtrty!!!
Thanks!!!
Well I got more accomplished last night before I fell asleep under the car somewhere around 3am. I managed to get the diff cover off, blast it, clean it, paint it, put a gasket in there (there wasnt one at all :/), and bolt it to the subframe.
I installed new axles because I messed up the boot on one of them and it was cheaper to order a set then use the rebuild kit anyways. So I returned the rebuild kit and ended up with these bad boys
Installing them was a bit of a challenge since I wanted to put them on outside of the car. I used two Allen keys with the new hardware I bought and held the axle in place with one while I use the other key to torque the other axle into place.
The result was very satisfying though
I then managed to BY MYSELF raise the sub frame into the car with two dolly's, a floor jack, two jack-stands, and some misc wood. I only have a few pictures here as this was extremely hard by myself. I could have waited for help, but I was anxious to get it together.
In the end, I managed to get it installed and the drive shaft bolted up. I had to wedge the sub frame studs back through the holes behind the interior panels, slight pounding and yelling ensued. I also installed the new sway bar links(while I laughed and made jokes about the cute sway bar that most likely does nothing anyways) and also ran all the new stainless brake lines, and bolted the ABS sensors and Ebrake cables back into place. Somewhere along this process is where I fell asleep on the comfy Creeper and woke up confused around 4am. I will take pictures when I finally install the brakes and power bleed the system very soon!!!
Do not use the axle nuts that come with those half shafts, buy new ones and lock plates.
It all looks so shiny!
Do not use the axle nuts that come with those half shafts, buy new ones and lock plates. It all looks so shiny!
Wait what? I have new axle nuts for the half shalfs and I have new locking plates as well. Why should I not use them?
Are they OEM Halfshafts?
If so no worries. -
If so no worries.
They are not, but I got them on Worldpac, so they are high quality. Have you had an Axle nut fail before?
I had issues with the supplied hardware for an aftermarket or reman axle once, the axle also lasted 150 miles lol.
I have not had good luck with aftermarket axles, so I hope these work fine for you. -
Ahh, yeah I have had issues with axles before on other cars. These look to be great quality, I am not too worried. I will let you know if a few thousand miles how they hold up.
I never shared photos of pressing the new bearings in.. So let me step back a sec...
Heres the tool of choice...
using some random old bearing races and chunks of aluminum, I was able to press out the hubs, then the bearings.
One thing I learned from this whole ordeal was that it sucks if you accidentally bend the shields. They hold the e-brake shoes a specific distance from the swing arms. Once they are tweaked, it takes a lot of manipulating and patience to get them just right again so that everything lines up. Something that should have taken me 20 minutes now took me over 2 hours.
At the end of the day, everything went together well and I was happy.
Before
After
