DP's and JB4 Removal Wanted
Im pretty sure the dealer in Milwaukee might .. turn there heads at the downpipes. Id call and ask but dont give them a vin? id remove the jb4 for sure tho
The build date is 4/20/2007. The warranty is based on the in-service date which for my car is June something 2007.
Ok, that contradicts what I was told by Zimbrick in Madison but if you can get a few more months out of them then that's awesome!
Having worked there I can tell you they will not. Any aftermarket part they will tell bmw about when they make the puma case for authorization to do the turbos.
What's the last 7 of your vin #? I will look into it. I know the rattle bulletin they have out is for e60 and e90 were they say to program. I also know they have been not covering the turbos just because of rattle. Aka needs to have boost faults or such. But like stated I will look into it and get back to you. Most likely will be able to get it coveted though without you having to remove anything.
Huh, that's strange because they were the ones that told me about the in-service date. I also emailed BMWNA and they confirmed what Zimbrick said.
I know some one personally who went to the Milwaukee dealer and they did the swap with the catless pipes. Its a matter who you know i guess regardless id save cash on the swap back and forth to upgrade the turbos with better ones. Just because the rattle will come back. Nature of the beast
I'll probably just keep the cats on after the switch to avoid the hassle in the future if the same problem occurs.
Which turbo is causing you the rattling issue? Mine is specifically the front. I took mine into Dubuque and Davenport BMW dealerships to try to get mine fixed (still all oem) and they turned their noses up at it. They were trying to "adjust" the wastegates (I could do this just as well), and charge me 16 hours shop time. Im going to go with either upgraded twins or big single.. not dealing with it anymore..
That sucks that they won't do anything about it. I took mine to Zimbrick in Madison and it was there for a few hours and they called me and told me they were going to replace them. They were very easy to work with.
I had the same experience at Zimbrick.
