  3. Services Offered/Wanted
  4. DP's and JB4 Removal Wanted
25 Posts 9 Posters 429 Views 1 Watching
  • Bobdudeman1988B
    Bobdudeman1988B
    Bobdudeman1988
    Im not really sure. Whats the year and mileage. Lots of times the rattle can be reduced by adjusting the waste gates. Lots of times also dealers will upload a new dme flash that will rob throttle response but keep the waste gates quiter
      reckedhim
      tsweers89 said:
      Hopefully it doesn't go away once you put the stock cats back on. Having done many do installs for some reason installing catless downpipes amplifies it. Aka a car that had no noise what so ever had the rattle after we installed them. You have an extended warranty or are you close to the factory mileage warranty on yhe turbos? Also for $250 I can get them replaced just how you are set up now. But you will have to take a drive to Chicago.
      Well, if it does go away with the stock cats, oh well.  I just don't want to hear it any more.  And I was referring to the factory mileage warranty for the turbos.  I'm in Madison but don't mind taking a drive since there's not really anyone around here.
        reckedhim
        it's an '07 with about 65k.
          What is the build date?  I ask because the warranty goes off of the build date on your car not the production date.
            reckedhim
            The build date is 4/20/2007.  The warranty is based on the in-service date which for my car is June something 2007.
            • Bobdudeman1988B
              Bobdudeman1988B
              Bobdudeman1988
              Im pretty sure the dealer in Milwaukee might .. turn there heads at the downpipes. Id call and ask but dont give them a vin? id remove the jb4 for sure tho
                Ok, that contradicts what I was told by Zimbrick in Madison but if you can get a few more months out of them then that's awesome!
                • T
                  T
                  tsweers89
                  Having worked there I can tell you they will not. Any aftermarket part they will tell bmw about when they make the puma case for authorization to do the turbos.
                  • T
                    T
                    tsweers89
                    What's the last 7 of your vin #? I will look into it. I know the rattle bulletin they have out is for e60 and e90 were they say to program. I also know they have been not covering the turbos just because of rattle. Aka needs to have boost faults or such. But like stated I will look into it and get back to you. Most likely will be able to get it coveted though without you having to remove anything.
                      reckedhim
                      Huh, that's strange because they were the ones that told me about the in-service date.  I also emailed BMWNA and they confirmed what Zimbrick said.
                        Whenever I called on warranty service for other makes on the used lot it was always by in-service date.
                        • andyhundleyA
                          andyhundleyA
                          andyhundley
                          • Bobdudeman1988B
                            Bobdudeman1988B
                            Bobdudeman1988
                            I know some one personally who went to the Milwaukee dealer and they did the swap with the catless pipes. Its a matter who you know i guess regardless id save cash on the swap back and forth to upgrade the turbos with better ones. Just because the rattle will come back. Nature of the beast
                              reckedhim
                              I'll probably just keep the cats on after the switch to avoid the hassle in the future if the same problem occurs.
                              • T
                                T
                                tsweers89
                                Sent you a pm. Please give me a phone # to contact you.
                                • Chris WelterC
                                  Chris WelterC
                                  Chris Welter
                                  Which turbo is causing you the rattling issue?  Mine is specifically the front.  I took mine into Dubuque and Davenport BMW dealerships to try to get mine fixed (still all oem) and they turned their noses up at it.  They were trying to "adjust" the wastegates (I could do this just as well), and charge me 16 hours shop time.  Im going to go with either upgraded twins or big single.. not dealing with it anymore..  :mad:
                                  2009 335XI: JB4, DCI, Tein Springs, Custom exhaust, Single Turbo, Port Injection, VRSF 7", ...
                                  2002 Suburban: DD and toy hauler.
                                  1996 Jeep Grand Cherokee: Come buy this I dont want it anymore!
                                  • e36mpwrE
                                    e36mpwrE
                                    e36mpwr
                                    The new JB4 update eli mates the rattle thank god
                                      reckedhim
                                      That sucks that they won't do anything about it.  I took mine to Zimbrick in Madison and it was there for a few hours and they called me and told me they were going to replace them.  They were very easy to work with.
                                        I had the same experience at Zimbrick.
