  3. BMW Discussion
  4. 1991 325i m20 help, madison
67 Posts 10 Posters 1.1k Views 1 Watching
    cpandrewschmidt said:
    did the vacuum test, at idle it was at about 11ish PSI.  Pushing the gas in neutral it would jump up to 17-18.  All lines and hoses seem seem intact.  Anyone ever try the cigar smoke test on these cars?  Where would i introduce the smoke into the system?
    Changing fuel filter tomorrow.  Cleaned ICV
    Every time i start the car it seems to get worse.  I'm stumped as problems only arose after doing routine maintenance and I haven't driven the car more than 20 miles from swapping parts.  I don't think I will make it to anyone's shop who's offered to help me (thanks again by the way you guys!) without breaking down as bad as its running.  Don't suppose anyone is around the westside that could help for a beer?
    Andrew
    The idle vacuum is too low.  Is it steady, fluttering, or wandering?  That is an ok reading when at higher RPM on that particular gauge, 17-18 is actually around 21-22 inHg.  (inches of mercury, a smaller measure of pressure).
    You are sure the cam timing lined up right?  You should try removing each spark plug wire one at a time and see if there is one that does not make a difference.  There could be a bad wire even though they are new.  You will see the result immediately if the cylinder was working properly.   This would rule out a spark issue that is possibly one cylinder only.  Maybe a wire didn't get crimped right or the cap is deformed.
    • C
      C
      cpandrewschmidt
      Thanks guys, I'll try both tonight and report back. I'm 99% sure that timing is right. I did the timing belt in December and drove it back and forth from rimrock road to verona a couple times without issue before performing the plug and were changed. I did those in February.
      • C
        C
        cpandrewschmidt
        Did the plug check over lunch.  That checked out fine.  Unpluged each one, the engine would change sound a bit, then as I got the wire close to the plug you could hear each one spark.  After connecting the engine sounded normal.  So, I don't think there's a misfire issue.
        When I do the smoke test tonight I think this is the correct brake booster line to disconnect?  There are two in this area, one right on top of the other.
        post-3545-0-93693400-1427313731thumb.jp
          Pick a different line , you will have a tough time removing that one. What are you using for the smoke test?
            Maybe it would be easier to unhook the ICV and use that connection.
            Obviously getting a Sam's Club pack of Swisher Sweets and hyperventilating into the intake?
            • C
              C
              cpandrewschmidt
              I could use the ICV but then won't I be missing if there's a leak from that a point forward through the airbox?  Is there a better part in the system to blow into to capture everything?  At the fuel pressure regulator hose?  If so, should I blow from point 1 or 2 attached?  Thanks, never done this before, should be fun.
              Yeah, just using some old cigars.  Gonna have to be sure not to inhale too much or I'll get a mad buzz.  Wait, or maybe I should? :)
              Andrew
              post-3545-0-72828700-1427318232thumb.jp
                Andrew
                The pressure drop happens across the ICV and throttle body plate so any leaks on the airbox side of those 2 things is not as much of an issue.  It will only let a slight amount of air through that did not get metered by the air flow meter (flapper thing in the intake).  The pressure on the airbox side of the throttle plate and ICV will be very close to atmospheric.
                • C
                  C
                  cpandrewschmidt
                  well, i didn't do the vacuum test yet.  Changed the fuel filter and went for a drive around the neighbor hood.  While compression could be better I don't think it's really a major vacuum leak.  Here's why.  While driving it starts out running pretty good, strong acceleration, reasonably smooth.  A little rough, but drive able.  The problem gets REALLY bad after the car warms up.  I'll try to attach a video. (video didn't work, ugh)  You can't hear sound all that well, but the engine is about to cut out.  Probably would if I let it keep going it sounds BAD.  You can see the temp gauge flicker, mpg, etc.  Again, only gets terrible after it warms up.
                  So, I think I can rule out bad plugs and wires cause it goes fine for a bit.
                  I noticed while jacking the car up to change the filter I have a bad gasket after my catalytic converter.  There was A LOT of water/exhaust liquid dripping out.  Not gas though, didn't smell. just vapor.  Could mean nothing, could mean something, i don't know.  Not sure how the problem only happening when up to operating temp might play into all that.
                  Thanks again for all your help.  Sure would be nice to get her running for spring.
                    Interesting, does it idle low, high, or surging?  If you give it a little gas to bring the rpms up does it smooth out?
                    • C
                      C
                      cpandrewschmidt
                      idle is fine until it's warm.  it starting surging real bad while driving.  i limped it back to the garage, put in neutral and it would still surge badly.  i shut it down then and came on here.
                      been doing lots of searching online.  Does the fuel pressure regulator make any sense that it'd fail when engine is warm?  I gotta find some westsiders that I can swap parts with.
                        Have you considered the possibility of a bad head gasket? Is the coolant dirty or is the dipstick milky?
                        • C
                          C
                          cpandrewschmidt
                          i think that's OK.  nothing milky in oil.  i've popped the cap and looked good when i did the valve cover gasket before changing the oil
                            Surging when warm can be caused by the ecu coolant temp sensor.  My e30 would surge once warmed up randomly until I cleaned the connector that plugs into it.  It can be a misleading problem because the dashboard gauge is a separate sensor.  It will cause a too rich condition because it thinks the engine is still cold.  I would check this to rule it out.  Do you have a multimeter?
                            Here is a detailed testing procedure.  http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug
                              This is very similar to what I have going on with my e30 except mine doesn't surge at idle when up to temp, it high idles instead.
                              As a side not when I was looking for sensors online shopping via ECS and BluntTech they both had the ecu and dash sensors listed as "water temp sensor". I'm replacing both just cause.
                              • C
                                C
                                cpandrewschmidt
                                I picked up an ECU coolant temp sensor cause it was $16, figured i'd just try that and I'm not out much if it isn't it.  Probably on its way out anyways if I have the original.  I'll get that in tomorrow and let you know.  Badger game to watch tonight!
                                  Did the one you bought have two contacts on the connection?
                                  • C
                                    C
                                    cpandrewschmidt
                                    Yes
                                    • C
                                      C
                                      cpandrewschmidt
                                      well, the ecu coolant temp didn't do anything.  next guess is fuel pressure regulator i think unless someone else has another idea.  Anyone know if I could take one off of a e28 5 series?
                                        Compare the part numbers on realoem
                                          Just out of curiousity disconnect the O2 sensor and see if that makes a difference with the surging.
