pistonse30
    Any insight to the central locking unit and wires would be greatly appreciated.
      For shits and giggles I looked it up on google and the first hit was a v8 buick forum. They have done it without issues so it must be good=P
        Got the e36 drive shaft painted up and the e30 CSB on it.
        Comparison pictures of the e30 and e36 DS:
        Painted. Zipties FTW!
        Ready to go!
        On to the Evo 3 Shifter.
        The clip of the beeeaches.
        Had to use a vice grips to get it installed.
        New rear mount.
        Top side c-clipped in.
        New ZHP Knob to top it off.
          Fancy!  The DSSR is what makes it good.
            That should be coming in the mail tomorrow.
              I have bad news. The dssr will not fit on that selector rod joint as is. You need to sand the integrated bushings
                Were they designed to fit the old one?
                  Yup
                    Thanks for the heads up
                      No problem=)
                        All new everything
                        Rigged up
                        Torqued to 74 ft/lbs.
                        UPS should be delivering the SS slave cylinder line today.  I'll get that installed and bleed the system.  Tomorrow the DSSR should be here.  More than likely will have to sand down the selector to make it work.
                        After that all I'll have to do is:
                        - Drive shaft
                        - Diff and axel
                        - Change oil
                        - Turbo gasket
                        - Cut the tial BOV spring a little
                        - Shifter gasket thing, boot and ZHP knob
                          So close, I'm sure you are ready for boosting!
                            Heading back into the garage now!!
                              You're flying through this thing! Keep up the awesome work
                                Must be nice to sit at home all day working on your car and taking pictures!
                                  Thanks!!
                                  Haha! The life of a Realtor. I'm taking calls, scheduling appointments and wrapping up some accepted offers. I have a rental showing in Stallis at 5:30. Anyone want a 3br 2ba house for $1400?
                                    Stallis blows
                                      Back in the garage...
                                      Took the red/blk wire loop out of the door connector by splicing it out.  Once I connected the wires something clicked in the central locking unit or interior light module.  Good sign??
                                      This might be the problem.  Central Locking Unit.
                                      Turned my attention to the stereo system.
                                      Got a new sub amp.  600w Kenwood to replace my old 500w Alpine.
                                      Also got new 3 new Stinger RC cables and routed them on the drivers side hopefully to eliminate the whining that matches the RPMs when they vary.
                                      Headed back into the bimmer cave now!
                                        Hooked up,the new amp and nada. Took the speaker out and tested the two coils. 2ohms a piece.
                                        Sorry for the iPad pics. Camera battery died.
                                        Other things I got done.
                                        - Tried to bleed the slave but the pedal doesn't feel right. It doesn't sit on the floor when pressed. It's spongie feel to it. I'm using an e36 m3 slave. Any tips? Also was using a vacuum pump on the slave bleeder while having my fiancée pump and hold the pedal.
                                        - Cut a ring out of my BOV. I'll order the replacement springs tomorrow but there is no rush. The yellow spring was in there from Tial.
                                        - Replaced the passenger side fog light. The old one had a crack in it.
                                        - Cleaned up a bit.
                                          Scooped up a new sub this morning.
                                          Wired it up to 2 ohms and installed it.
                                          My next project.  Installing a working glove box to hide all this.
                                          UPS just dropped of a small box!  Into the garage!!
