  4. The E46 M3 Journal
The E46 M3 Journal
536 Posts 34 Posters 0 Views 1 Watching
    Just a reminder that a lean misfire can show up as a rich mixture. Hope it gets better soon
      Light is still on...going to shift my attention to the mass air flow sensor
        Random pic on Lake Dr.
        Took the car into Urban Motorworx for the engine mounts and passenger side arm as well as a look into the too rich bank 1 & 2 codes.
          Might need to do a head gasket on this beast. Compression test to come.
          Doesn't seem too tough. I did a eta to i head swap 11 years ago so it has to be like riding a bike.
          http://www.adrianteo.com/files/cylinder-head%20_S54_.pdf
            Is it running rough? or just losing some coolant?
              Slightly rough. I'll donsome more digging and report back.
              • T
                T
                tsweers89
                Headgasket on this is not even close copared to a e30. Needing special timing tools and such. Also a good time to do vanos rebuild if in fact you need to do this.
                  I have the inverted torx sockets. I'm good, Timmy
                    Need to go through this list one by one.
                    P0171 - System to Lean (Bank 1/2) :
                    * Fuel system
                    * Excessive fuel pressure.
                    * Leaking/contaminated fuel injectors.
                    * Leaking fuel pressure regulator.
                    * Low fuel pressure or running out of fuel.
                    * Vapor recovery system.
                    * Induction system:
                    : : - Air leaks after the MAF.
                    : : - Vacuum Leaks.
                    : : - PCV system.
                    : : - Improperly seated engine oil dipstick.
                    * EGR system:
                    : : - Leaking gasket.
                    : : - Stuck EGR valve.
                    : : - Leaking diaphragm or EVR.
                    * Base Engine: :
                    : : - Oil overfill.
                    : : - Cam timing.
                    : : - Cylinder compression.
                    : : - Exhaust leaks before or near the HO2Ss.
                      How about throttle body balance? Are those adjustable?
                        They are but I'm getting too lean on all banks. I'm debating on going back to a stock tune if the air flow sensor doesn't do the trick. Of course after doing a compression test.
                          The S54 ecu is much more advanced than megasquirt, but I just want to be my best self and point out that this wouldnt be an issue on megasquirt
                            I do here a puttering like those old Chevy trucks with a exhaust manifold leak. This could be a big issue with the O2 sensors but would it be throwing a too lean for bank 1&2??
                              Yes.  Any leak before the cat that's monitored by your pre-cat o2 will mess with your afr's and can cause a too lean.
                                Did some work on the M3 today with the help of Dan The Exhaust Man.  Now waiting on parts that should be showing up tomorrow.
                                4 out of the 6 cylinders were leaking at the exhaust ports due to loose bolts.  Hmmm, why do some shops reuse one time use components?!!?
                                Just got the valves adjusted... leaking oil??
                                Took some material off of the motor mount and its heat sheild to make room for the header.16798104281fb9961a263b.jpg
                                Missing some material.  This is the #6 cylinder which has had the most issues.
                                  What headers are going on?
                                    The same that were on before. Just installing the correct hardware the correct way. Getting all BMW parts from Concours.
                                      Seeing this work makes me angry.  I dedicate a lot of my time training technicians and service managers and trying to pound into their heads that auto repair is a professional industry and we should carry ourselves accordingly.  You are only as good as the quality of work you put out and the image you portray.  If you want to be treated like a "grease monkey" and you want to lie to customers by putting out crap work and denying liability when faults are pointed out then you will never make it for any length of time in this industry.  What bothers me most is that shit like this only perpetuates the idea that all technicians are selling snake oil and cheating and stealing there way to a paycheck.  There are honest shops and honest techs out there but these cock gobblers keep fucking it up!  The customers loose out the most in this whole thing because they feel they need to question every recommended service or repair and waste time getting 2nd opinions or just flat out not believing anything and not getting the repair done at all!
                                      /rant
                                        I am going to try to always do my own work and make time for it even with my busy schedule.  Every time I go back over a shop's work I always find something wrong.
                                        Kummrow has cost me lots and lots of money with re-using one time use parts and over torquing everything they touched on both the e30 and e46. I just hope to god that they torqued the head down properly.
                                        Urban Motorwerx did a good job on what they did but didn't find any exhaust leaks on 4 of 6 cylinders?!  They did find some loose nuts and missing studs but never mentioned that the gaskets might be bad or the leaks were still there.  And the oil leaking from the back of the valve cover has me concerned that they reused the valve cover gasket but I will never find out for sure.
                                        My new approach is working hand-in-hand with Dan the Exhaust Man.  He builds roll cages, drag cars, and the like.  A finish carpenter turned mechanic.  Details, details, details.  Takes his time but moves fast when he needs to and he has me helping out.  We got the headers out in two hours of me pulling up to his shop. Now cleaning up the contacting sides of the head and headers, removed and cleaned all of the studs, brake clean in the head holes for the studs and will do red loc-tite to secure them.  Slapping some copper sealant on the gaskets when we install them and using NEW OEM 11mm nuts that will be snugged up.
                                          So ready for the summer wheels...
                                          Wiped down the paint and did the windows with the completion of the wheel swap.
