  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Interesting, this is why I do everything myself, I just don't trust anyone else to do it how I would. The only thing I can't do is mount tires and do an alignment, my neighbor works at a shop and I get those things done by him.
    Sent from my potato phone
      Matt is awesome at Urban MotorworX!
      • T
        T
        tsweers89
        If you could be so kind to inform us all who this "shop" is that did the shady work on your vehicle so we all stay away that would be great!
        • T
          T
          tsweers89
          Anyone that is interested Kumrow is the peopel who did the questionable "work"
            I'm still g3tting "too rich cod3s on bank 1&2" so I just popp3d in a f3ul pump.
            I'm going to pump.you.up
            1ffb443a61fa817767e0a9de848a3978.jpg4d512f8207cb3b56c69dca96d4bba771.jpga2f23be2ec404a6f595e0025240cb1e7.jpg8374d941f6f763b478ff27ebc266b141.jpg4b34c2aeb6be262278c93844c3dae742.jpg
            Sup3r 3xciting!!!
              Just a reminder that a lean misfire can show up as a rich mixture. Hope it gets better soon
                Light is still on...going to shift my attention to the mass air flow sensor
                  Random pic on Lake Dr.
                  Took the car into Urban Motorworx for the engine mounts and passenger side arm as well as a look into the too rich bank 1 & 2 codes.
                    Might need to do a head gasket on this beast. Compression test to come.
                    Doesn't seem too tough. I did a eta to i head swap 11 years ago so it has to be like riding a bike.
                    http://www.adrianteo.com/files/cylinder-head%20_S54_.pdf
                      Is it running rough? or just losing some coolant?
                        Slightly rough. I'll donsome more digging and report back.
                        • T
                          T
                          tsweers89
                          Headgasket on this is not even close copared to a e30. Needing special timing tools and such. Also a good time to do vanos rebuild if in fact you need to do this.
                            I have the inverted torx sockets. I'm good, Timmy
                              Need to go through this list one by one.
                              P0171 - System to Lean (Bank 1/2) :
                              * Fuel system
                              * Excessive fuel pressure.
                              * Leaking/contaminated fuel injectors.
                              * Leaking fuel pressure regulator.
                              * Low fuel pressure or running out of fuel.
                              * Vapor recovery system.
                              * Induction system:
                              : : - Air leaks after the MAF.
                              : : - Vacuum Leaks.
                              : : - PCV system.
                              : : - Improperly seated engine oil dipstick.
                              * EGR system:
                              : : - Leaking gasket.
                              : : - Stuck EGR valve.
                              : : - Leaking diaphragm or EVR.
                              * Base Engine: :
                              : : - Oil overfill.
                              : : - Cam timing.
                              : : - Cylinder compression.
                              : : - Exhaust leaks before or near the HO2Ss.
                                How about throttle body balance? Are those adjustable?
                                  They are but I'm getting too lean on all banks. I'm debating on going back to a stock tune if the air flow sensor doesn't do the trick. Of course after doing a compression test.
                                    The S54 ecu is much more advanced than megasquirt, but I just want to be my best self and point out that this wouldnt be an issue on megasquirt
                                      I do here a puttering like those old Chevy trucks with a exhaust manifold leak. This could be a big issue with the O2 sensors but would it be throwing a too lean for bank 1&2??
                                        Yes.  Any leak before the cat that's monitored by your pre-cat o2 will mess with your afr's and can cause a too lean.
                                          Did some work on the M3 today with the help of Dan The Exhaust Man.  Now waiting on parts that should be showing up tomorrow.
                                          4 out of the 6 cylinders were leaking at the exhaust ports due to loose bolts.  Hmmm, why do some shops reuse one time use components?!!?
                                          Just got the valves adjusted... leaking oil??
                                          Took some material off of the motor mount and its heat sheild to make room for the header.16798104281fb9961a263b.jpg
                                          Missing some material.  This is the #6 cylinder which has had the most issues.
