  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Okay, got a lot fixed.
    - The EGT sensor wire had sheared off and replaced with a new one.
    - One O2 sensor was replaced.
    - The #6 injector was leaking and was replaced.
    - Valve job was due so got it done but everything wasn't too out of wack.
    - Hood latch sensor was replaced.
    - An exhaust stud on the #5 cylinder was missing. Got a new one in there.
    - A new belt, tensioner and idlers were all replaced.
    - Rear trunk latch was replaced.
    The cherry on top was the previous shop that installed the headers, after extremely scratching off the ceramic coating, more than likely removed the passenger side engine mount to provide room. Well, while Urban MotorworX was re-installing the missing exhaust stud he noticed the engine mount didn't have any bolts. After further inspection only one bolt was still on holding the broken piece of the engine mount to the block. THE WHOLE ENGINE WAS RESTING ON THE STEERING RACK! That would explain the weird vibrations I've been dealing with. This is also why the EGT sensor was sheared off. Matt installed two bolts to bandaid the problem for the time being. Tuesday the new arm will be here. Not sure if the previous shop over torqued the bolts and with my hard driving they came loose or if they were tight in the first place *cough, exhaust stud, cough*. After thousands and thousands of dollars spent on fixing issues of incompetent mechanics at this shop my word of advise to the community is please steer clear.
    The car is running amazing at the moment. I am getting a too lean code from bank one and two but I think that might be the tuning that needs to be tweaked.
      Interesting, this is why I do everything myself, I just don't trust anyone else to do it how I would. The only thing I can't do is mount tires and do an alignment, my neighbor works at a shop and I get those things done by him.
      Sent from my potato phone
        Matt is awesome at Urban MotorworX!
        • T
          T
          tsweers89
          If you could be so kind to inform us all who this "shop" is that did the shady work on your vehicle so we all stay away that would be great!
          • T
            T
            tsweers89
            Anyone that is interested Kumrow is the peopel who did the questionable "work"
              I'm still g3tting "too rich cod3s on bank 1&2" so I just popp3d in a f3ul pump.
              I'm going to pump.you.up
              1ffb443a61fa817767e0a9de848a3978.jpg4d512f8207cb3b56c69dca96d4bba771.jpga2f23be2ec404a6f595e0025240cb1e7.jpg8374d941f6f763b478ff27ebc266b141.jpg4b34c2aeb6be262278c93844c3dae742.jpg
              Sup3r 3xciting!!!
                Just a reminder that a lean misfire can show up as a rich mixture. Hope it gets better soon
                  Light is still on...going to shift my attention to the mass air flow sensor
                    Random pic on Lake Dr.
                    Took the car into Urban Motorworx for the engine mounts and passenger side arm as well as a look into the too rich bank 1 & 2 codes.
                      Might need to do a head gasket on this beast. Compression test to come.
                      Doesn't seem too tough. I did a eta to i head swap 11 years ago so it has to be like riding a bike.
                      http://www.adrianteo.com/files/cylinder-head%20_S54_.pdf
                        Is it running rough? or just losing some coolant?
                          Slightly rough. I'll donsome more digging and report back.
                          • T
                            T
                            tsweers89
                            Headgasket on this is not even close copared to a e30. Needing special timing tools and such. Also a good time to do vanos rebuild if in fact you need to do this.
                              I have the inverted torx sockets. I'm good, Timmy
                                Need to go through this list one by one.
                                P0171 - System to Lean (Bank 1/2) :
                                * Fuel system
                                * Excessive fuel pressure.
                                * Leaking/contaminated fuel injectors.
                                * Leaking fuel pressure regulator.
                                * Low fuel pressure or running out of fuel.
                                * Vapor recovery system.
                                * Induction system:
                                : : - Air leaks after the MAF.
                                : : - Vacuum Leaks.
                                : : - PCV system.
                                : : - Improperly seated engine oil dipstick.
                                * EGR system:
                                : : - Leaking gasket.
                                : : - Stuck EGR valve.
                                : : - Leaking diaphragm or EVR.
                                * Base Engine: :
                                : : - Oil overfill.
                                : : - Cam timing.
                                : : - Cylinder compression.
                                : : - Exhaust leaks before or near the HO2Ss.
                                  How about throttle body balance? Are those adjustable?
                                    They are but I'm getting too lean on all banks. I'm debating on going back to a stock tune if the air flow sensor doesn't do the trick. Of course after doing a compression test.
                                      The S54 ecu is much more advanced than megasquirt, but I just want to be my best self and point out that this wouldnt be an issue on megasquirt
                                        I do here a puttering like those old Chevy trucks with a exhaust manifold leak. This could be a big issue with the O2 sensors but would it be throwing a too lean for bank 1&2??
                                          Yes.  Any leak before the cat that's monitored by your pre-cat o2 will mess with your afr's and can cause a too lean.
